Second question, no.
Third question, if you're talking about the Commando 273 dealy, it wasn't a decal, it was a piece of aluminum kinda like a pie plate but with an open middle, that was glued to the air cleaner top. If it's a decal, it's a reproduction.
Last question, they came in Plymouth and Dodge versions; Plymouth version said "Commando 273" and Dodge version said "Charger 273." Same air cleaner painted black with no pie plate was used on various early 60's big block 4-barrel engines, and with a different base on various slant sixes.
