Page 1 of 3 1 2 3
towing a classic with a classic? #1309065
09/22/12 11:26 PM
09/22/12 11:26 PM
North Central Florida
E
eightlitermopar Offline OP
E
I have a random question about moving some cars across the country related to the towing capacity of our old muscle cars.
Who here has hauled a classic mopar with another classic mopar?
I have a 71 roadrunner (383 auto) and a 69 coronet (318 auto).
Why couldn’t I drive one and pull the other one on a trailer?
I am in the planning mode and this will not happen anytime soon, but the “trip” would be 2400 miles.
Any other ideas about moving these two cars across the states?
I could get a 40’ trailer and haul them both at the same time with a truck, but that sounds risky too.
Your thoughts?
Eightlitermopar
Mopar or no car
Re: towing a classic with a classic? [Re: eightlitermopar] #1309066
09/22/12 11:41 PM
09/22/12 11:41 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i wouldnt hesitate for a second to haul that coronet 2400 mi. with my 69 GTX 440.it aint never gunna happen,just sayin.
Re: towing a classic with a classic? [Re: bonefish] #1309067
09/23/12 12:24 AM
09/23/12 12:24 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Its not a lack of power thats the problem here, its the lack of brakes and hitch mount. How are you going to mount the hitch and ball setup? Your talking about a 4,000lb car and a 1,500lb trailer being pulled by a 4,000lb car that wasn't designed for it. I do a lot of hauling, but I have the appropriate TRUCK. I also have at my disposal a 3 car trailer, so for me, not an issue. Its just not worth the risk of losing both cars because it "sounded like a good idea at the time". Like Jeff Foxworhty says, "Y'all wanna see this?"
Re: towing a classic with a classic? [Re: None2Slow] #1309068
09/23/12 12:29 AM
09/23/12 12:29 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Re: towing a classic with a classic? [Re: None2Slow] #1309069
09/23/12 12:35 AM
09/23/12 12:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A hitch going to the unibody frame should be able to handle it. Tongue weight is supposed to be 10% of trailer weight I think. So 10% of 5500lbs being 550... It would probably work but I personally wouldn't try it. Stability during braking while at speed would be questionable IMO.
Re: towing a classic with a classic? [Re: DaytonaTurbo] #1309070
09/23/12 01:02 AM
09/23/12 01:02 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I would not want 550 pounds hanging off the absolute ass end of an old passenger car unless there were some very stout and new springs under the axle.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: towing a classic with a classic? [Re: Secret Chimp] #1309071
09/23/12 01:06 AM
09/23/12 01:06 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
And shocks, and tires and its a unibody. Just asking for a darwin award IMO...
Re: towing a classic with a classic? [Re: Secret Chimp] #1309072
09/23/12 01:10 AM
09/23/12 01:10 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
derf.... double post
Re: towing a classic with a classic? [Re: None2Slow] #1309073
09/23/12 01:30 AM
09/23/12 01:30 AM
Manitoba, Canada
Manitoba, Canada
I sometimes forget the soggy springs a lot of guys have in their old cars. I have real stout springs in the back of mine. My frame (as skrawny as I am) barely can move my rear bumped up and down when pushing with all my weight on the trunk lid.
I guess another thing to consider as well is back in the day everyone used their cars for hauling. Plenty of old mopars had hitches and towed trailers. Maybe not 5500 pounds but they did tow.
Re: towing a classic with a classic? [Re: None2Slow] #1309074
09/23/12 03:18 AM
09/23/12 03:18 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Do they even make a hitch for that car that is up to the class rating?
Hitch Measurements
Class 1 (Class I) trailer hitch Trailer hitch with capacity of up to 2,000 lbs gross trailer weight and 200 lbs tongue weight.
Class 2 (Class II) trailer hitch Trailer hitch with weight-carrying rating of up to 3,500 lbs gross trailer weight and 300/350 lbs tongue weight.
Class 3 (Class III) trailer hitch Trailer hitch with weight carrying rating of up to 5,000 lbs gross trailer weight and 500 lbs tongue weight. Also sometimes used to refer to a hitch with any 2" receiver, regardless of rating.
Class 4 (Class IV) trailer hitch Trailer hitch with weight carrying rating of up to 10,000 lbs gross trailer weight and 1,000 - 1,200 lbs tongue weight. Although many times any hitch with a capacity greater than 5,000 lbs gross weight is referred to as a Class 4.
Re: towing a classic with a classic? [Re: None2Slow] #1309075
09/23/12 08:31 AM
09/23/12 08:31 AM
None
71rm23 Offline
71rm23  Offline
None
Rent or borrow a truck. No worries or headaches that way
Re: towing a classic with a classic? [Re: 71rm23] #1309076
09/23/12 10:48 AM
09/23/12 10:48 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Heck back in the day you towed with what you had. You didn't own a vehicle for every occasion. Big air stream campers were pulled by cars with the family riding in the car. A lot of cars were towed to races with tow bars not trailers.
Horses and cattle were hauled in the back of pick ups, not in trailers like today and likely those pick ups were 1/2 tons not big a$$ed dualies.
Drive accordingly.
Re: towing a classic with a classic? [Re: MoparforLife] #1309077
09/23/12 11:02 AM
09/23/12 11:02 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
As long as the frame rails aren't rusty and the disc brake system is in good order I don't see a problem along with good tires. I don't know if you can find a proper rated hitch these days though.
My Dad pull his Airstream with his 68 318 Fury, 71 383 Newport and 73 400 Charger all over hecks half acre.
Course Dad isn't a 2000 era girl in a boys body either.
Sheldon
Re: towing a classic with a classic? [Re: eightlitermopar] #1309078
09/23/12 01:00 PM
09/23/12 01:00 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
The only time I towed cross country, I used a tow dolly, and it was 'only' 800 miles (roughly).
The biggest issue wasn't the car, it was the other idiots on the road. People gawking at two old cars going down the highway, and the usual idiots cutting us off (I could never be a Trucker ). And I did this almost 14 yrs ago, BEFORE we had the texting and cell phone idiots we do now.
Would I do it again? HELL NO! Across town, sure. But, cross country? NO.
Pick a car to drive, and ship the other. You'll be glad you did.
John
Re: towing a classic with a classic? [Re: RUNCHARGER] #1309079
09/23/12 10:20 PM
09/23/12 10:20 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Sheldon
True, but then again we smoke cigarettes, chew tobacco and drink and drive knowing its not good for us. We do lots of thing were not supposed to do. Does it make it right?
Ohh and I am a truck driver and you are correct about the idiots on the road. Sometimes I wish I could just plow through the gene pool and take some of them out. Man, do we need more bleech or what?
Re: towing a classic with a classic? [Re: None2Slow] #1309080
09/23/12 10:40 PM
09/23/12 10:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I used to tow my 71 RR to the drags all the time with my 76 GMC Sprint. The trailer weighted 1600 LBS and the Sprint was powered with a 250 CID 6 cylinder.. 50 miles round trip every weekend with 1 big azz hill in the way..
I am truckless..
Re: towing a classic with a classic? [Re: 340SHORTY] #1309081
09/23/12 11:12 PM
09/23/12 11:12 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
My buddy Rich used to tow his A12 Road Runner with a 77 Newport. This would have been around 1990.
Re: towing a classic with a classic? [Re: pinkduster] #1309082
09/23/12 11:15 PM
09/23/12 11:15 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: towing a classic with a classic? [Re: pinkduster] #1309083
09/23/12 11:17 PM
09/23/12 11:17 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: towing a classic with a classic? [Re: pinkduster] #1309084
09/24/12 12:05 AM
09/24/12 12:05 AM
E
E
Hey pinkduster! those are the kind of ads that got me thinking!
We used to have a mowing business and pulled our big trailer with our 67 dodge coronet.
However, I do agree that I would be a nervous wreck and the proud new owner of an ulcer after pulling like that across country.
I'll scrap that idea...I have a few years to figure it out.
Maybe I'll take two road trips...one car at a time.
thanks for the input guys...I really am not suicidal
eightlitermopar
Mopar or no car
Page 1 of 3 1 2 3
