I am quickly running out of hair to pull out. My motor is a 360 .040 over, 11.8:1, J heads, Comp 292/299 .508 hydraulic cam. My issue is keeping valve springs in it, they are not breaking they are going weak after just a few passes. The springs that are in it are comp 995-16, installed height is 1.700 and they are supposed to be 115# at the seat. Last weekend I changed spring after only 25 passes on a new set. I was floating valves and checked the springs and they had 85-90# on the seat. On the first pass it started floating the valves again. Got home and checked they are at 90# on the seat. Any ideas as to what might be causing this or should I just shim the springs up and hope they don't loose any more.
