440 build quesions #130888
10/01/08 10:12 PM
10/01/08 10:12 PM
Moparnocar Offline OP
super street
super street
I have a combo that I think I want to run.. need some input and experiences or problems u have ahd.
I want to run a mopar performance 509 purpleshaft cam, with edelbrock alum heads.. with prw's 1.6 rooler rockers.. I am wondering what I should do to the bottom end... and also what spings I should use... any help would be great.. thanks
Re: 440 build quesions [Re: Moparnocar] #130889
10/01/08 10:48 PM
10/01/08 10:48 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
A steel crank, stock or aftermarket rods would be fine (you can even do with a cast crank but with so many steels out there why?), obviously aftermarket rods would be better but you should be fine with stock reconditioned, and a good set of forged pistons.
With open headers it will probably pull to about 6500 rpm. Probably in the 530-550 horse zone, it will run well. Alot of people will tell you stay away from the old DC509 and like it will be said theres better cams but it will make power. Maybe look at the .557 as an alternative without much downside for street manners but more power potential. With the 509 you'll probably want about 10-10.5 to 1 compression with the Eddy heads.
What do you want to do. Alot of people will probably come on and tell you that you need 12:1 compression, 4.10s, and 3500 stall for it and while it will perform better set up like this alot of 509 cams have been used on the street. Id look at other cams though simply because the Eddy heads would make more power with more lift. The DC cams are based more on racing with factory heads.
Re: 440 build quesions [Re: GTX MATT] #130890
10/01/08 11:53 PM
10/01/08 11:53 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Stock crank, be it cast or forged will be fine. Go with reconditioned stock rods or something like 440source's el cheapo rods. For pistons I'd go with KB237's if you don't mind hyper pistons. Mill the deck a little and you'll get a zero deck quench engine with those e-rpm heads.
I would scrap that 509 cam in favor of either a comp XE-HL cam or a Lunati Voodoo if you want to stay hydraulic. If you don't mind going solid, Comp and Lunati have some very nice, proven offerings.
Re: 440 build quesions [Re: DaytonaTurbo] #130891
10/02/08 12:03 AM
10/02/08 12:03 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Run a new cam, the 509 is outdated. MP is prone to having soft lobe junk made anyway.
I want my fair share
Re: 440 build quesions [Re: GTX MATT] #130892
10/03/08 04:50 PM
10/03/08 04:50 PM
super street
super street
I just want to make some good streetable power without afecting drivability.. So I should ditch the 509... I was also thinking the comp cams XE284H as an option.. So its seems I'm on the right track.. thanks all...
Re: 440 build quesions [Re: Moparnocar] #130893
10/04/08 09:25 AM
10/04/08 09:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the 509 isn't much of a street cam. It requires 3000+ stall, 3.91 gears or better, 10:1 or better, good flowing heads, headers and such to work. Otherwise it will be a DOG off the line.
Re: 440 build quesions [Re: Mr.Yuck] #130894
10/06/08 12:18 PM
10/06/08 12:18 PM
usa
mrmopardan Offline
mrmopardan  Offline
usa
Thats' my setup in a fully dressed 68 "B" body street car... OOTB aluminum RPMs & Crane 1.5 iron adjustable rockers. Last time out 12.5 @ 109. Old school but still fun!!
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: 440 build quesions [Re: SomeCarGuy] #130895
10/06/08 12:27 PM
10/06/08 12:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Have any PROOF to back up that statement ?
Re: 440 build quesions [Re: JohnRR] #130896
10/06/08 12:38 PM
10/06/08 12:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
John, you know how that goes... In any case, the original .509 is not a streetable cam for 75% of those that run it and actually get one installed where it's designed to be... (i think the lobes are fine.. if they could just get them in the right spot!!)
I'd use the Comp Magnum 292. It's quieter than the XE line, easier on springs, and will live a bit better on the street. If you have power brakes, the XE274H would be my first choice for you.
Re: 440 build quesions [Re: JohnRR] #130897
10/06/08 01:21 PM
10/06/08 01:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah put a 509 cam in a 8.75:1 440 w/ logs, a dual plane intake say a holley 750 vacuum carb, 2200 stall and 3.23's and you'll get a DOG. It's not a cam designed for the street. It doesn't make any power until you get the rpms up. Same goes for the 484. Don't make me google the MOPAR engine builders guide circa 1980.
If you have good compression, good heads, good exhaust, 3000+ stall and some gear it's a nice cam.
Re: 440 build quesions [Re: Mr.Yuck] #130898
10/06/08 09:05 PM
10/06/08 09:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do agree that the .509 needs the right combo to work good. You dont throw the .509 in a stock 383 Roadrunner using a stock converter with logs and 3.23's as you will have a low end pig. But I will say I used the MP.484 in a 9.5 comp 383 with 3.91's and a 3000 converter that worked great for a street Dart at 3600 with driver. It ran 12.30's @ 110 mph so you cant say it wont work as everyone who told me it wont work and ran milder cams had slower cars then that Dart. And that 383 was not really what I call a car with alot of gear and converter or comp. The .509 will want more comp , gear and converter then the .484 does.
Back to the original question my answer is no I would not use the .509 in a very mild close to stock bigblock. I would only use it in the right combo as the .509 may be dated but in the right combo it makes great power. Ron
Re: 440 build quesions [Re: Mr.Yuck] #130899
10/06/08 10:20 PM
10/06/08 10:20 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
There is nothing wrong with the 509 or any of the old Mopar grinds.They work really well.
Nautilus Racing-
Re: 440 build quesions [Re: Chris2581] #130900
10/06/08 11:40 PM
10/06/08 11:40 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Are MP cams ground for the 904 lifter diameter?
Re: 440 build quesions [Re: GwaiiEagle] #130901
10/07/08 12:03 AM
10/07/08 12:03 AM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
It's the same company that gave us .904 diameter lifters to begin with. MOPAR
Re: 440 build quesions [Re: elmor] #130902
10/07/08 01:07 AM
10/07/08 01:07 AM
dogdays Offline
dogdays  Offline
Yes, BUTTTT,
At over 240 degrees at 50 lift it is at least 0.040 short on lift compared to modern grinds. It is by no means taking advantage of the 0.904 lifter. Take a look at the Hughes cams for what can be done with the 0.904 lifter. Or the Comp XE HL series or the VooDoo cams which seem to have different lobes for Chrysler cams.
The other thing to do is GET RID OF THOSE HEAVY PISTONS! You are building an engine with high rev valvetrain and head capabilities, get the reciprocating mass down from 1100 grams with pin to around 750 grams with pin. That's 350 grams, about a pound. At the top of the stroke where acceleration is highest, you are looking at thousands of Gs. That one pound "weighs" thousands of pounds at that point.
R.
