crank trigger or new distributor #1308937
09/22/12 08:56 PM
09/22/12 08:56 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
After installing new t chain and bronze gear ignition timing still retards 5*@4000. Been looking at different distributors and just looked at an msd crank trigger for small block.
What are the pros and cons of a crank trigger for street strip duty?
Re: crank trigger or new distributor [Re: mopar dave] #1308938
09/22/12 09:20 PM
09/22/12 09:20 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
crank trigger its the way to go. dead on timing...after you get one you will never go back.
Re: crank trigger or new distributor [Re: Plymouth340] #1308939
09/22/12 09:47 PM
09/22/12 09:47 PM
Mt Morris Michigan
Mt Morris Michigan
How tough would it be to install?
Re: crank trigger or new distributor [Re: mopar dave] #1308940
09/22/12 09:55 PM
09/22/12 09:55 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
First question i have is what Brand blancer do you have and bolting the crank trigger is pretty easy. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: crank trigger or new distributor [Re: mopar65] #1308941
09/22/12 10:15 PM
09/22/12 10:15 PM
Mt Morris Michigan
Mt Morris Michigan
Pro comp.
Re: crank trigger or new distributor [Re: mopar dave] #1308942
09/22/12 10:22 PM
09/22/12 10:22 PM
mopar65 Offline
mopar65  Offline
Pro comp.
Does it have a flat face or does it have a recess wear the pulley bolts on? i ask this because i had the new stile fluid dampener that the Mounting face for the pulley was recessed in. I was trying to use a MSD crank trigger and it would not work.I had to have a spacer made that would support the center of the crank trigger. mopar65
Re: crank trigger or new distributor [Re: mopar dave] #1308943
09/22/12 10:51 PM
09/22/12 10:51 PM
AndyF Offline
AndyF  Offline
I went with a crank trigger and a belt driven distributor. That combo cleaned up a bunch of issues.
Re: crank trigger or new distributor [Re: AndyF] #1308944
09/22/12 11:24 PM
09/22/12 11:24 PM
mopar65 Offline
mopar65  Offline
very nice looking set up you have there Andy and when i get the money i will be going the crank trigger route too.Mopar65
Re: crank trigger or new distributor [Re: mopar65] #1308945
09/22/12 11:54 PM
09/22/12 11:54 PM
Mt Morris Michigan
Mt Morris Michigan
damper has a flat face. nice set up there andy. what brand of crank trigger is that? what brand can anyone recommend.
Re: crank trigger or new distributor [Re: mopar dave] #1308946
09/23/12 12:07 AM
09/23/12 12:07 AM
Mt Morris Michigan
Mt Morris Michigan
sorry i was wrong. damper is a compitition products/proffesional products.
Re: crank trigger or new distributor [Re: mopar dave] #1308947
09/23/12 12:41 AM
09/23/12 12:41 AM
mopar65 Offline
mopar65  Offline
well you are all set then. i would just get the msd version.
here is what the one looks like that i was using.
http://www.fluidampr.com/product/720311/
Re: crank trigger or new distributor [Re: mopar dave] #1308948
09/23/12 04:30 AM
09/23/12 04:30 AM
408Dust Offline
408Dust  Offline
Crank trigger should be mandatory when using that dampner, it will keep the outer ring from flying off your motor when the screws back out or break.
Re: crank trigger or new distributor [Re: 408Dust] #1308949
09/23/12 10:23 AM
09/23/12 10:23 AM
Mt Morris Michigan
Mt Morris Michigan
i had a fluid dampner at one time. i understand the problem you had. MSD is the best one i'v looked at yet with the flying magnets.
Re: crank trigger or new distributor [Re: 408Dust] #1308950
09/25/12 05:09 PM
09/25/12 05:09 PM
Washington
SuperStock68Dart Offline
Washington
had this happen three times to me while running customer cars on the chassis dyno....flying ring of death!!! ATI is all I use
Re: crank trigger or new distributor [Re: SuperStock68Dart] #1308951
09/25/12 08:09 PM
09/25/12 08:09 PM
Mt Morris Michigan
Mt Morris Michigan
You had three rings come the proffessional products dampner? Never heard of anyone having trouble with them before.
Re: crank trigger or new distributor [Re: mopar dave] #1308952
09/25/12 08:13 PM
09/25/12 08:13 PM
408Dust Offline
408Dust  Offline
I had two of them come off only thng that kept them from comng all the way off was the crank trigger.How that dampner got a SFI rating is beyond me,do yourself a favor and buy a ATI.
Re: crank trigger or new distributor [Re: 408Dust] #1308953
09/25/12 08:30 PM
09/25/12 08:30 PM
Mt Morris Michigan
Mt Morris Michigan
Next time it comes off i will. Installing crank trigger tomorrow. Instructions suck,but should'nt be too bad.
Re: crank trigger or new distributor [Re: mopar dave] #1308954
09/27/12 12:54 PM
09/27/12 12:54 PM
Washington
Washington
Yes I did...we had the above ground Dynojet....so the cars were up in the air on the lift. The rings would come off and fly around the shop....kinda like the old video game "pong"!
