You'll get more responses in the Q & A catagory...
What is your timing set at, initial and total? This can affect header tube temperature.
It takes a while for the lifters fully pump up and quiet down. -OR- Do you think there was something wrong with the initial adjustment that you need to re-adjust them?
Only that fabric header wrap can stand that kind of heat. Better to heat shield the starter if it's that close.
Do your electric pump and fans work? Did you drill a small hole in the thermostat to bleed the air out of the system?
Fire it back up and break it in....without the fire this time.
