Source For Speedo Gear Please #1308801
09/22/12 04:21 PM
09/22/12 04:21 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I am in need of a new speedo gear for my 727. I changed the rear gear in my 8.75" from 2.76 to 3.55 and need to get ready for when my gauges come back from Intrument Specialties.
Looking online indicates I need part # 2438933 (33 tooth yellow) speedo gear. Can anybody confirm if this is right? Car has 3.55 rear gear with 28" tires (275/60R15).
Does anybody here (sponsor maybe) sell these gears? Can anybody here point me in the right direction on the best place to order one from. Anybody here have on laying around they would sell?
I saw the thread earlier with somebody else was looking to replace their speedo gear and this jogged my memory to go ahead and swap mine.
Is there anything else I will need when I do the swap?
Thanks!!
Re: Source For Speedo Gear Please [Re: cjskotni] #1308802
09/22/12 07:04 PM
09/22/12 07:04 PM
I would see what a dealer wants for one and I've seen em for sale in the parts for sale sections here good used. I would put a piece of flat stock across a rear tire and measure the exact diameter to ground. People have said the MP charts in the archives ain't accurate plus I should use rollout to get the actual dia (Circumference "rollout" divided by Pi = dia) but I used it as is with my gear ratio to make my selection & it made the odo (& the speedo) come in dead on.
Re: Source For Speedo Gear Please [Re: cjskotni] #1308803
09/22/12 07:46 PM
09/22/12 07:46 PM
STL
cdstl Offline
cdstl  Offline
STL
This is what I found sometime back:
A&A Transmissions: http://www.aandatrans.com/Departments/Chrysler-727-Trans/Speedometer-Gears.aspx
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Source For Speedo Gear Please [Re: cjskotni] #1308804
09/22/12 09:39 PM
09/22/12 09:39 PM
scratchnfotraction Offline
CRT list them for 20 bux each till you get up to the 35 tooth then it jumps to 75 bux.
you can find them on ebay,here in for sale section.
i have a few and just sold a 32 tooth one with the housing to another member.
i dont have any yellow ones but have a 32 and a 35 gear and a few smaller and larger ones.
you may get it close enuff to live with if you cant score a yellow one.
look in the trans section,seems I just saw a bunch of them for sale here also.
Re: Source For Speedo Gear Please [Re: scratchnfotraction] #1308805
09/22/12 10:46 PM
09/22/12 10:46 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
I just checked my small stash of gears. I've got a 32, and a 34. Sorry.
Nothing to see here. Carry on.
Re: Source For Speedo Gear Please [Re: scratchnfotraction] #1308806
09/23/12 08:16 AM
09/23/12 08:16 AM
tboomer Offline
tboomer  Offline
Scratch...How many teeth on a yellow one? I think I have one....
Ooops!! Just re read this...33 teeth!
Re: Source For Speedo Gear Please [Re: tboomer] #1308807
09/23/12 09:44 AM
09/23/12 09:44 AM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
There is a guy on here that I bought one from, don't remember who it was. He has 100s of them. Real nice transaction.
Just post a an ad in the wanted section here & he should reply.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Source For Speedo Gear Please [Re: cjskotni] #1308808
09/23/12 09:59 AM
09/23/12 09:59 AM
Retired now in Tennessee
Chi_Town_Runner Offline
Brewers stocks some.
Here's a link:
Brewers
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Source For Speedo Gear Please [Re: Chi_Town_Runner] #1308809
09/23/12 03:03 PM
09/23/12 03:03 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
I checked the tranny section of parts for sale on this site. Didn't find the pinion gear I needed then went to fleabay. Found the right one for $9 delivered. Looked as good as new. When refering to the pinion chart to get the correct numbered tooth pinion gear, I needed to go one higher. For example, after doing the math, if the chart said I needed a 33 tooth, the 34 tooth gave me the correct speed reading. Same again for another application. The chart said I needed a 26 tooth, but the 27 was more correct. But anyway, the chart gives you a ballpark of where you need to start.
Re: Source For Speedo Gear Please [Re: moparjo68] #1308810
09/23/12 04:04 PM
09/23/12 04:04 PM
Franklin CT
syleng1 Offline
syleng1  Offline
Franklin CT
Layson's has them according to their catalog. I called my local dealer looking for one and they were unable to get them anymore.
Joe
