THIS IS FUN,FUN,FUN...................... #1307597
09/20/12 06:19 PM
09/20/12 06:19 PM
State of confusion
Thumperdart Offline OP
State of confusion
I dug into my wiring yesturday afternoon and was in the garage till 3:20 am and have been at it for a few hours this morning and it`s going great so far. Thinking about re-vamping my stock fuse box or can I just buy a fused bar and put my pos, keyed on and so forth where I want em? I`ve already removed loads of dead wires and wired up my dash cluster and am sending one pos. and one neg. wire out to the fuse box instead of tying up several posts. I`m also isolating all of my other gauges to a bus bar which I split in half for grounds and pos. wires instead of tying up the ford realy pos. post..........back to work and thankxxx for all of the tips.
Re: THIS IS FUN,FUN,FUN...................... [Re: Thumperdart] #1307598
09/20/12 06:51 PM
09/20/12 06:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
as long as you are getting a minor headache all is going OK
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: THIS IS FUN,FUN,FUN...................... [Re: tex013] #1307599
09/20/12 08:59 PM
09/20/12 08:59 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Sounds like your off to a pretty good start. Make sure you make a schematic as you go. Years from now you'll thank yourself.
Re: THIS IS FUN,FUN,FUN...................... [Re: tex013] #1307600
09/20/12 10:55 PM
09/20/12 10:55 PM
State of confusion
State of confusion
Thankxx............So far all of my accessories(fuel pump,water pump and elec fan) are re-wired and good to go but now comes the fun part of tying into the fuse box wires. Again can I use the few wires I need, ditch the fuse box and get a fused strip to do the same thing?
Re: THIS IS FUN,FUN,FUN...................... [Re: Thumperdart] #1307601
09/21/12 01:48 AM
09/21/12 01:48 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
If I had three or four circuits I would think strongly about in line fuses
home of the
Sox and Martin Hemi Duster
Re: THIS IS FUN,FUN,FUN...................... [Re: HEMIFRED] #1307602
09/21/12 05:21 AM
09/21/12 05:21 AM
State of confusion
State of confusion
I ended u re-using the existing stock fuse box for now but may change it out if I don`t like it. The factory connectons for the steering wheel and dash were shot so I bypassed em and tied the wires to a junction block which looks way better and should work better due to some burned up wires I found in the factory connections. Just have a few more wires to go then we`ll see what happens..........
