2 questions -
I have a car that had 2.71 gears originally [8 1/4],and put in a set of 3.55 gears instead. I do have on order a 35 tooth speedometer gear[and seal kit] thru A+A Transmission, which shows to be correct per the site calculator. [245/60/15 tires]
Any trick to swapping the speedometer gear ?
Is it just unscrew the cable,pull the housing on the trans, swap the seals, insert the new 35 tooth gear, bolt back in ?
In the meantime the Speedo seems to be reading 15-20 mph high at what i think is 40mph down the road [ reads 55mph]. IS there a certain fixed percentage error i should expect, if so , how to figure it ?
72 B-body with factory rally 150 mph gage, i think it came with F70x14 tires from factory.
Thanks.
