A Body Trans Crossmember 4 Speed #1307041
09/19/12 08:41 PM
09/19/12 08:41 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
I have a 72 Dart 318 with the biscuit motor mounts and I have the newer spool type crossmember.
I seem like I have to elongate the holes more to make it work. Are they the same as the biscuit style cross or is that my problem??
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307042
09/19/12 09:04 PM
09/19/12 09:04 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I went 72 biscuit to 74 spool 3 speed to 4 speed. It fit fine. Also went with a urethane mount.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: A Body Trans Crossmember 4 Speed [Re: Rug_Trucker] #1307043
09/19/12 09:06 PM
09/19/12 09:06 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
I have biscuit on motor and trying to use spool type croos on 4 speed and it just barely misses the mount holes on the trans
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307044
09/19/12 09:11 PM
09/19/12 09:11 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Maybe (the biscuit) its reversed? Heres a pic that may help.
Re: A Body Trans Crossmember 4 Speed [Re: NV69B7RR] #1307045
09/20/12 09:23 AM
09/20/12 09:23 AM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
cant find that pic in your thread??
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307046
09/20/12 11:51 AM
09/20/12 11:51 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Have you tried turning the cross member around? Or does that make it worse?
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307047
09/20/12 12:05 PM
09/20/12 12:05 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Is there any chance that you have the wrong spool mount? Pickup and possibly van mounts are different than car mounts.
Re: A Body Trans Crossmember 4 Speed [Re: 446acuda] #1307048
09/20/12 02:47 PM
09/20/12 02:47 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
talked to passon and he said i could possibly have an f body mount he said they will do that.
does anyone have any pics of an old one with the mount vs. the newer to compare? that would help
thanks in advance
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307049
09/20/12 03:54 PM
09/20/12 03:54 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
truck/other?
Re: A Body Trans Crossmember 4 Speed [Re: 446acuda] #1307050
09/20/12 03:55 PM
09/20/12 03:55 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
car
Re: A Body Trans Crossmember 4 Speed [Re: 446acuda] #1307051
09/20/12 08:18 PM
09/20/12 08:18 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
here is the mount i currently have. if you look close enough you can see where I have been trying to rhem the hole out to make it work, but i would like to figure out the problem. the tailshaft is sitting back too far on the trans mount.
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307052
09/20/12 08:20 PM
09/20/12 08:20 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
back side
Re: A Body Trans Crossmember 4 Speed [Re: BIGJOE30] #1307053
09/20/12 08:27 PM
09/20/12 08:27 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
be nice to have both cross members to compare old style and new. it seems to me maybe the biscuit motor mounts move the engine back some and if I had the spool it would be more forward. i dont know anyone have both to do a side by side??
