Factory finish on fuel line vapor shield (E-body w N95) #1306880
09/19/12 04:35 PM
09/19/12 04:35 PM
Sweden
71redcuda Offline OP
Sweden
Need to know the factory finish on the fuel line vapor shield located behind the rear wheelhousing on the passenger side.The shield is only for cars with N95.Should itbe painted or is it plated like the repros?
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: 71redcuda] #1306881
09/19/12 04:41 PM
09/19/12 04:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
definitly not painted.
I want to think mine old one was galvanized,,, but thats not 100% etched in my mind either
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: gtx6970] #1306882
09/19/12 04:45 PM
09/19/12 04:45 PM
Sweden
Sweden
My thought also,thanks Bill. Any ideas of what the correct screws for it might be?
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: 71redcuda] #1306883
09/19/12 05:15 PM
09/19/12 05:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy's old '70 T/A with California N95 Emissions. I pretty sure it's not galvanized on this car.
Don't all 1971 car have this? N95 or not?
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: autoxcuda] #1306884
09/19/12 05:19 PM
09/19/12 05:19 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
wrong one
and that shield on my old car was gloss black
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: gtx6970] #1306885
09/19/12 05:22 PM
09/19/12 05:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This is what I was talking about.
And even though this says they're the same , I think 1970 was different than 1971's
or maybe it was cudas were different than challengers?( don't remember )
not sure about the on all 71's part
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: gtx6970] #1306886
09/19/12 05:40 PM
09/19/12 05:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
wrong one
This one in the very top right corner behind the tire?
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: gtx6970] #1306887
09/19/12 05:43 PM
09/19/12 05:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
wrong one
What was the plant and SPD of your car?
IIRC, you had a A66 340 1970 Challenger?
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: 71redcuda] #1306888
09/19/12 05:48 PM
09/19/12 05:48 PM
California
1970mopar Offline
1970mopar  Offline
California
They are painted black.
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: 71redcuda] #1306889
09/19/12 08:33 PM
09/19/12 08:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a 71 N95 car and mine was painted black when I took it apart or had black paint on it. The car was never apart before I got it.
Re: Factory finish on fuel line vapor shield (E-body w N95) [Re: autoxcuda] #1306890
09/19/12 10:12 PM
09/19/12 10:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
wrong one
1970 Challenger 340 .
LA plant early Dec 1969 , CA emmissions car( spent most of its life in San Fransisco)
I don't remember it having any paint on it,(maybe some undercoating ) but the car had near 100K miles on it, so I guess it could have worn off over time
