I was just test fitting the speed pro rings for my 360 and something doesn't seem right. I'm getting 0.016-0.017 gap for the top rings, 0.018-0.019 for the second and between 0.027-0.028 for the oil rings. The 1st and 2nd rings are on the tight side no? These are not supposed to be file fit.
The big thing I see is the oil expander, it has these clear plastic inserts at the each end of the gap I've never seen before. And it has to be forced into the bore, with the ends butted tight to each other. The old expander rings have a good size gap when in the bore.
These are moly rings, part number is E251K and they are the marked for the right bore size. (0.040 over) I'm almost sure this is the same part # ring set I used when I put the motor together originally in '03, but what's in the box is different.
