Re: 425hp in a 66 B'Cuda any advice
[Re: Joesixpack]
#1306549
09/18/12 08:07 PM
09/18/12 08:07 PM
Actually, the chassis is pretty much identical to later Plymouth A bodies except the front frame rails are closer together and the front wheels are two inches further back. I have examples of both, and I believe the early ones are overall less flexible than the later ones.
But yeah, subframe connectors and disc brakes should be high on your list. If it's a factory V-8 car with 10" drums, they are not so terrible, but discs are still a huge improvement.
And if you don't already have HD torsion bars and rear springs, you'll need to upgrade them, too. Good thing is they are interchangeable with all A bodies 1963 through 1976.
