Lexan And Stickers #1306490
09/18/12 04:43 PM
09/18/12 04:43 PM
MR_P_BODY Offline OP
I'll be going on Drag Week next year and to my understanding
its mandatory to have the class and car number on
the back window.... mine is Lexan and I want to be
able to take it off after DW is completed... how would
you suggest I do it... I dont want to put it directly
on the lexan... I'm open for ideas ... I have to be
SUPER CAREFUL with this window... I cant take it out
due to the back bars going through it
Re: Lexan And Stickers [Re: MR_P_BODY] #1306491
09/18/12 04:55 PM
09/18/12 04:55 PM
K
Kiddart Offline
Kiddart  Offline
K
use a very thin coat of vasiline on the back of the sticker(Glue Side), as long as you dont get wet or try to wash the car to much you should be just fine. try this on a spare piece if you have some with a junk sticker just in case
Thank you
Kiddart
Re: Lexan And Stickers [Re: MR_P_BODY] #1306492
09/18/12 04:58 PM
09/18/12 04:58 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Could you use the vinyl material that sticks but there is no glue? Like the kids use on a window I forget what the name of it is.
http://wallstickeroutlet.com/peel-and-stick-decals.php
something like this but not sure if it would stay put at speed.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Lexan And Stickers [Re: MR_P_BODY] #1306493
09/18/12 05:01 PM
09/18/12 05:01 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Mike , I had new number decals made for my windows this year and to get the old ones off I just used a heat gun and warmed them up a little . They came right off.
Re: Lexan And Stickers [Re: super451b] #1306494
09/18/12 05:08 PM
09/18/12 05:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
When I have to run "temporary" stuff on my lexan on the big tire car we use painters tape, the yellow stuff. We put it on the glass, place the decal on it and then trim around the outside. It has worked well. I have had some decals peel off the margard on my windows so if it is temporary we use tape.
Re: Lexan And Stickers [Re: Savoy1964] #1306495
09/18/12 05:09 PM
09/18/12 05:09 PM
I know the static stickers dont stay on... I tried
using them for my dial in some years back
Re: Lexan And Stickers [Re: Al_Alguire] #1306496
09/18/12 05:12 PM
09/18/12 05:12 PM
Thats a good idea... never thought of that tape down
first then the stickers... I'll have to test it out
