E Body Dash Pad Replacement. #1306268
09/18/12 07:44 AM
09/18/12 07:44 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I need to replace the black dashpad in my 72 Barracuda. Was wondering how big of a job this is. Anyone have any removal/install tips. Looks to me like it's going to be a bear to do. Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: E Body Dash Pad Replacement. [Re: TimS] #1306269
09/18/12 10:04 AM
09/18/12 10:04 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Here's a brief overview of the steps. Found it here at Moparts years ago:
They installed these at the factory as on piece, dash
pad, dash, instruments, et all. I've found it easier
just to remove the whole thing and then strip it down
on my work bench. Along the top of the dash are four
screws usually in the vent openings. You can see them
from outside the car looking in. Drop the steering
column, remove all the trim around the dash including
kick panels. There are two bolts one on each side of
the dash, loosen these and the dash will tilt forward.
Disconnect the wiring harness from the bulkhead
connector, miscellaneous connections at the heater,
headlights, dimmer switch, door switches, and the
whole thing can be removed. It's a heck of a job, but
then you can check, clean, rebuild , repaint anything
on the dash. Good luck.
Re: E Body Dash Pad Replacement. [Re: mrob] #1306270
09/18/12 10:46 AM
09/18/12 10:46 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Don't forget the speedo cable
Re: E Body Dash Pad Replacement. [Re: DAYCLONA] #1306271
09/18/12 12:35 PM
09/18/12 12:35 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
So this can all be done with the windshield in place, or is it significantly easier with windshield removed?
Re: E Body Dash Pad Replacement. [Re: mrob] #1306272
09/18/12 09:23 PM
09/18/12 09:23 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the info. Sounds like at least a 2 man job.
Re: E Body Dash Pad Replacement. [Re: rss] #1306273
09/18/12 09:49 PM
09/18/12 09:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes, and Yes...
Re: E Body Dash Pad Replacement. [Re: DAYCLONA] #1306274
09/19/12 12:31 PM
09/19/12 12:31 PM
U.P. ,MI.
P
plumcuda Offline
plumcuda  Offline
P
U.P. ,MI.
I replaced the dash in my '73...I thought it was easy.I was also replacing the carpet so I had the seats and console out.When you have the dash out,it's a good time to overhaul the heater box.
Re: E Body Dash Pad Replacement. [Re: plumcuda] #1306275
09/19/12 01:19 PM
09/19/12 01:19 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I was going to do that also, remove the front seats. Did you remove the steering column as well? Sounds like it's also best to remove that whole dash assembly.
Re: E Body Dash Pad Replacement. [Re: TimS] #1306276
09/19/12 02:28 PM
09/19/12 02:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The first one I did was with the dash frame in place in the car. It was pretty hard to get to all the stamped nuts to get it off. I don't think I got them all back on because it is so tight.
The second one I did was out of the caR AND IS THE ONLY WAY i WOULD DO IT AGAIN.
Windsheild does not have to come out to remove the dash assembly.
I clamped mine to a homemade T support that I use for my miter saw to support wood when cutting. Used a visegrip to clamp it on.
Where's there's a will there is a way. I built and assembled this whole car by myself, everything you see in my pictures, everything by myself!
Re: E Body Dash Pad Replacement. [Re: Challenger 1] #1306277
09/19/12 11:07 PM
09/19/12 11:07 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
using the new pad as a guide to find the nuts and screws will help, did mine in a day..most of the day was used to clean up what you dont see under the pad...windshield stayed in..column dropped down to the seats..1/4 inch socket set with a swivel...
Re: E Body Dash Pad Replacement. [Re: AARCONV] #1306278
09/20/12 04:21 AM
09/20/12 04:21 AM
808CUDA Offline
808CUDA  Offline
I agree with Al, not that complicated to do it in the car with the windshield. Try doing a late model car with a ton of wiring...
Lower the column, pull the glovebox liner out, pull out the gauges and switch panel and have at it with swivel sockets. If it takes you more than 4 hours consider another hobby :P
