Page 2 of 6 1 2 3 4 5 6
Re: New Worst! Kaboom! [Re: Dragula] #1306152
09/18/12 10:29 AM
09/18/12 10:29 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
YEEEOW!! That's some serious carnage...sooo sorry for you loss.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: New Worst! Kaboom! [Re: Dragula] #1306153
09/18/12 10:30 AM
09/18/12 10:30 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
looking at that was painful enough to make a grown man cry. sorry about the carnage, glad you and the car are undamaged.
Re: New Worst! Kaboom! [Re: Mr.Yuck] #1306154
09/18/12 10:31 AM
09/18/12 10:31 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
I kinda know how your piston looks w/o seeing it.
If you look at the last picture of parts on the paper tower left to right it it, Piston, pushrods, lifters, cam and pieces of the block.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New Worst! Kaboom! [Re: Dragula] #1306155
09/18/12 10:33 AM
09/18/12 10:33 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That is a bummer of the first magnitude.
Glad it didn't wind up worse , but in spite of confining the damage to inside the motor , that is plenty ugly.
Ouch !
Re: New Worst! Kaboom! [Re: tubtar] #1306156
09/18/12 10:38 AM
09/18/12 10:38 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
sorry for your loss
Re: New Worst! Kaboom! [Re: sixpackgut] #1306157
09/18/12 10:59 AM
09/18/12 10:59 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Man I am sorry to see that. You have one of my favorite cars on the site because it is raced and driven so often. Could a broken valve spring cause that chain of events to begin? Again very sorry for your new engine.
Re: New Worst! Kaboom! [Re: Jeremiah] #1306158
09/18/12 11:38 AM
09/18/12 11:38 AM
Ma
Voluster Offline
Voluster  Offline
Ma
Man That Sucks!!!
Tore that up pretty good
Good luck getting something back together
Re: New Worst! Kaboom! [Re: Triple Threat] #1306159
09/18/12 11:52 AM
09/18/12 11:52 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
brought the car home and after work today pushed it in the garage and pulled the intake off....
Sorry to see this and that`s a LOT of damage. Any ideas asto what exactly happened at this point?..........
Re: New Worst! Kaboom! [Re: Thumperdart] #1306160
09/18/12 11:56 AM
09/18/12 11:56 AM
Idaho
LaRoy Engines Offline
Idaho
Sure enough son, you done "Hinkled" that motor, same cylinder Buck did!
Re: New Worst! Kaboom! [Re: Triple Threat] #1306161
09/18/12 11:57 AM
09/18/12 11:57 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Ouch!
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: New Worst! Kaboom! [Re: Triple Threat] #1306162
09/18/12 12:01 PM
09/18/12 12:01 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Daaaaayyyyyyyyymmmmmmmmnnn! Thats nasty! Dustin what series Manley valve was that? I guess the head is junk too? Crank?
Re: New Worst! Kaboom! [Re: Triple Threat] #1306163
09/18/12 12:05 PM
09/18/12 12:05 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
WOW Dustin I am so sorry. Hate to see that damage. Do you have another block to work with? What block are you running?
Old Geezer Racing
Re: New Worst! Kaboom! [Re: SCATPACK 1] #1306164
09/18/12 12:14 PM
09/18/12 12:14 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Sorry to see that, OUCH! Glad you are OK.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: New Worst! Kaboom! [Re: Jeremiah] #1306165
09/18/12 12:16 PM
09/18/12 12:16 PM
Renton Washington
Renton Washington
The springs (Comp) and retainer (Comp tool steel?) both look fine, Need to check the pressure on it. So far found I have found 1 of the 2 keepers, other is probably in the bottom of the pan or something, I haven't spent too much time looking around.
At this point I think the entire short block is a write off. The crank was already 10/10 so I doubt it will clean up. I don't remember what series valve it was off the top of my head, it wasn't top tier but it wasn't bottom shelf either. I don't think the valve is to blame, but I could be wrong. I had a ton of P to V clearance.
I'm pretty sure the head can be fixed/saved, but wont know for sure until I take it off. At this point I'm thinking about switching to a big block or maybe 3G Hemi. If anybody has anything feel free to PM me.
I'm wearing all black today...
-Dustin
Re: New Worst! Kaboom! [Re: Triple Threat] #1306166
09/18/12 12:54 PM
09/18/12 12:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is the stem straight? What was the open pressure of the springs?
Re: New Worst! Kaboom! [Re: Triple Threat] #1306167
09/18/12 12:58 PM
09/18/12 12:58 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Did it turn a bearing and cause the rod to break or break a rod bolt? Could be something else but most times that's what happens.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: New Worst! Kaboom! [Re: MRMOPAR622] #1306168
09/18/12 01:17 PM
09/18/12 01:17 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
It almost looks like the rod is still in one piece and attached to the crank, it just spent some quality time destroying the cylinder after the piston came apart. Hard to tell without seeing the crank side though.
I feel your pain man. I'd probably start throwing things across the room after witnessing what was under the intake manifold....
Re: New Worst! Kaboom! [Re: justinp61] #1306169
09/18/12 01:19 PM
09/18/12 01:19 PM
Renton Washington
Renton Washington
Yes, stem is still straight, pulled right out of the guide from the top. I don't remember the open pressure off the top of my head. 145# on the seat comes to mind. It was just a solid FT cam, double springs spec'd for the cam, installed by the porter.
Rod is still attached to the crank and in 1 piece as far as I can tell.
Re: New Worst! Kaboom! [Re: Triple Threat] #1306170
09/18/12 01:27 PM
09/18/12 01:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My guess is the head came off the valve.
Re: New Worst! Kaboom! [Re: justinp61] #1306171
09/18/12 01:31 PM
09/18/12 01:31 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
That's a real shame....we all feel your pain !
Glad to hear the car (and you) didn't sustain any damage.
Ron
