Fuse box #1305717
09/17/12 04:26 PM
09/17/12 04:26 PM
O
onebad340 Offline OP
O
Am replacing old fuse box with new one from Painless. Most of it fairly simple although I have one place on old box is labeled LP. It is a big wire prob 10 or 12 gauge that goes to the fuse with a 20 amp fuse. This is on a 1972 Dodge Demon. Any ideas what this is? Thank you.
Re: Fuse box [Re: onebad340] #1305718
09/17/12 04:54 PM
09/17/12 04:54 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
headlamps?
Re: Fuse box [Re: mikemee1331] #1305719
09/17/12 06:13 PM
09/17/12 06:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Headlights aren't fused.
Re: Fuse box [Re: stumpy] #1305720
09/17/12 06:22 PM
09/17/12 06:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
no? didn't know that. it would still be lamps.
Re: Fuse box [Re: mikemee1331] #1305721
09/17/12 08:30 PM
09/17/12 08:30 PM
O
O
So if lamps it would have to be headlights. Cant think of anything else that needs that gauge wire. Also dont know if they are fused or not
Re: Fuse box [Re: stumpy] #1305722
09/17/12 08:39 PM
09/17/12 08:39 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
What happens when ya get a short?
I have mechanical Aptitude.
I can screw up anything.
Re: Fuse box [Re: bboogieart] #1305723
09/17/12 08:58 PM
09/17/12 08:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you have to flip the breaker in your house quickly before the car burns up!
Re: Fuse box [Re: mikemee1331] #1305724
09/17/12 09:28 PM
09/17/12 09:28 PM
I'm not grasping the "LP" but with that large of gauge could it be for A/C or the heater. Cant think of any other large draws. As said the headlights are circuit breaker protected (instead of a fuse) inside the headlight switch
