Best way to clean internal engine parts
#1305676
09/17/12 02:33 PM
09/17/12 02:33 PM
Posts: 1,782 Miami, FL
wylde8
Miami, FL
I'm about to mount an engine block I have on my engine stand and start assembling it. Many of the internal parts for the engine, such as the crankshaft and rod/piston assemblies, have been sitting out for a while now. What's the best way to clean the dust off the parts? I'm sure a parts washer would work great, but I don't have one of those.
1971 Dodge Charger
At Moparts, the concensus is there is no consensus.
Re: Best way to clean internal engine parts
[Re: hooziewhatsit]
#1305682
09/17/12 04:49 PM
09/17/12 04:49 PM
RapidRobert
Be prepared to oil it FAST. I use a good spray bottle (cheap ones wont last) and fill it part way with eng oil then add the right amount of solvent to thin it out to the right proportions & shake it up to mix the two & I'm ready & it's fast & cheap
[Re: RapidRobert]
#1305683
09/17/12 05:02 PM
09/17/12 05:02 PM
Posts: 27,474 So Cal
autoxcuda
So Cal
Laundry soap mixed with water in a bucket. Hand cleaned with an Engine bottle brush kit you can buy from Summit. (two long bottle brushes on ground behind feet in picture below) Then soapy mix sucked/mixed into a shop air pressured spayer (hanging off bucket in picture below). Then hosed soap off. Then pressurized air dry. Then all machined surfaced wiped down with Justice Brothers JB-80 to keep it from rusting. JB-80 will protect much longer and better than most common stuff out there. Immediatly masked and painted the inside of the block rustoleum to seal casting and promote oil drainback.
[Re: Mr. Smurf]
#1305685
09/18/12 03:40 PM
09/18/12 03:40 PM
Dishwasher...
Ed
Yep, used to do that too..
..until the wife walked in unexpectedly soon one day!
You would've thought I was caught fornicating with the neighbors wife!
[Re: crazyjjk]
#1305687
09/19/12 09:38 AM
09/19/12 09:38 AM
Challenger 1
Cincinnati, Ohio
The hotter the water the better just because it evaporates quicker leaving less time to cause rust. That's an old trick black powder shooters used cleaning there rifles with soap & water. Get it as hot as you can stand so the water doesn't stick around.
EXACTLY, I have used my steam pressure washer to clean many engines, trans, gear boxes, pumps, diffs, you name it, I cleaned it with my pressure washer. It has been so worth owning it, mine get's over 212 or right at it.
It's nasty, dirty, wet job but works great.
[Re: dogdays]
#1305689
09/19/12 03:22 PM
09/19/12 03:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
