Stage V 2 x 4 intake, how much power potential?
#1305309
09/17/12 03:57 AM
09/17/12 03:57 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Just got the hemi nightmare fired for the first time last night, ti has got hte stage V 2 x 4 single plane intake and I was wondering how well they have performed? Will take it to the dyno soon if it survived the initial warm up.
Re: Stage V 2 x 4 intake, how much power potential?
[Re: jyrki]
#1305310
09/17/12 10:52 AM
09/17/12 10:52 AM
Posts: 376 Helsinki,Finland
Hemi_K
Helsinki,Finland
No one answers - what the heck ? IŽll give you a couple of sentences from e-mails from Tim Banning @ FHO. We were talking about the potential of that StageV intake... "Just about every engine we build today is a 540 or 572, as they cost no more to build than a 426 or 472. (roller cam engines have no problem exceeding 800hp)The larger engines make quite a bit more torque." "We have been able to build 800hp street engines with good heads and cams of .640 lift, 266 duration, on 112 centerlines. Some engines, due to intake or head restrictions, may require more aggressive lobes, typically, 268/272 duration, with lift numbers in the high sixes. If your head flow curve is slanted to high lift only, you may need to run one of our Pro-street camshafts, which are .700 plus, with durations in the 275-280 range on a 112 centerline." I would too really like to hear Moparts members real life experiences ! weŽll get back - I guess Jyrki will give you our numbers when we have dynoed my engine weather I like it or not..... If there is no more answers to this topic we can use Finnish as well
[Re: jyrki]
#1305313
09/17/12 01:17 PM
09/17/12 01:17 PM
PasiR
My motor made 790hp@6600 and 705lbft@5300 with same intake. I have undestood that in your motor everything is "bigger" so it will be interesting to hear how it run in dyno.
[Re: sasquatch]
#1305317
09/17/12 06:22 PM
09/17/12 06:22 PM
Posts: 311 Kingsville, Md
grncpe
Kingsville, Md
just dynoed my 588 last week with a stage v intake.The inside was massaged a bit with 2 800 thunder series carbs.made 836 hp. @ 6700 729 tq. @ 5100. I didnt put it on kill either so there is more left in it... here is some video http://www.youtube.com/watch?v=6CQJT_p-WN0
[Re: grncpe]
#1305318
09/18/12 12:54 PM
09/18/12 12:54 PM
Hemi_K
Helsinki,Finland
Oooh that sound is sooooooo beautiful Like music to... actually it sounds like a healthy Hemi ! Jyrki massaged my intake also - I think quite heavily... i have to choose between 750 holleys or 800 edelbrocks. with my previous engine (690hp 471" Hemi) the holleys worked better. Would you share a little more of your engine specs ? CR, cam, ported heads.... Just got off the phone, dyno time is next saturday the 29th. CanŽt wait to see what happens....
