72 dart big bolt pattern conversion
#1305275
09/17/12 02:40 AM
09/17/12 02:40 AM
Posts: 975 Page AZ
Diplomatt
Rodney Dangerfield Jr.
Page AZ
Edit: The dart has drums all around, not discs up front like I had thought.
So, what conversions for A bodies have all of you used? Are there any bolt on kits that use the drum spindles, or is it pretty standard to have to convert to '73-up parts?
I was thinking of going with the F/M/J setup, since those parts are relatively easy to find, but want to know what other options are out there.
Re: 72 dart big bolt pattern conversion
[Re: Diplomatt]
#1305281
09/20/12 01:05 AM
09/20/12 01:05 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Part of what I'm worried about is that I'm going to be using the Hotchkis uca's and I want to make sure what I get for the car will work with that setup.
That's an issue. I don't know if anyone has put aftermarket calipers and disks on a car with Hotchkis Upper Control Arms.
I could not run rear mounted pin type calipers with 11.75 disk with the Hotchkis Upper Control Arms. I just moved the Calipers to the front which is fine with 73-76 Sway Bars or 67-72 Hotchkis sway bars (end links moved inward).
[Re: Diplomatt]
#1305282
09/20/12 02:21 AM
09/20/12 02:21 AM
Posts: 31,036 Oregon
AndyF
All bets are off when you start mixing and matching parts from different aftermarket vendors. That is rule number one when building a hot rod.
[Re: Kern Dog]
#1305284
09/20/12 08:16 AM
09/20/12 08:16 AM
Posts: 4,323 NY NY
340duster340
NY NY
You raise a good point, if you also need to convert to v8 might as well swap all front suspension and brakes to 73\76 set up. You can always swap ucas at a lkater date.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
