Hello,
We are in the process of redoing the Navy interior in our 1966 Coronet 500. The seat covers, door panels, upper door frame paint and dash pad have metallic in them. Is this correct? Are the kick panels supposed to be metallic also?
Also, should the bottom of the carpet on the door panels be finished on the lower edge similar to the Chargers?
Thank you for any insight you may have on this!
