Fuel Pressure Tester, Diesel #1305195
09/16/12 10:37 PM
09/16/12 10:37 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Does anyone know, can I use a gas fuel pressure tester to connect to and test a Cummins diesel?
Specifically I'm wanting to check my lift pump preaasure after the filter by connecting to the schrader valve.
I know the testor specifically says not for diesel but I cant understand why
Thanks in advance
Re: Fuel Pressure Tester, Diesel [Re: AAR#2] #1305196
09/16/12 10:41 PM
09/16/12 10:41 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Lift pump pressure should be well within the range of a gasser, I'd try it...
Re: Fuel Pressure Tester, Diesel [Re: Bill MeLater] #1305197
09/16/12 10:49 PM
09/16/12 10:49 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Lift pump is 15-20, I was wondering if there is a reason the gas gage would'nt work, or break down (mybe different seals or provide a false pressure). Or is this simply a safety to keep some one from hooking up after the high pressure injector pump and blowing the gage face off?
Re: Fuel Pressure Tester, Diesel [Re: AAR#2] #1305198
09/16/12 11:07 PM
09/16/12 11:07 PM
Wisconsin USA
Wisconsin USA
It's not the seals...Probably liability
Re: Fuel Pressure Tester, Diesel [Re: Bill MeLater] #1305199
09/17/12 09:37 AM
09/17/12 09:37 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I have used an old air conditioning gauge set.
