B Body Fuel Line Install Question #1305192
09/16/12 10:28 PM
09/16/12 10:28 PM
California
BigDaddy440 Offline OP
California
Fuel Line Install Question. (Video Clip Below)
Although it is seemingly simple, I want to make sure I'm installing my new prebent fuel line and return line correctly on to my 69 Roadrunner.
The main issue: In order to get my 1/4 return line to fit into a factory fuel clip, I might have to tweek it a bit. BEFORE I start bending it up, to MAKE it fit, I wanted to ask people here and see what advice I can get. Thanks.
Also, does the bigger fuel line runner nearer to the ground the entire distance of the car?
I've made a quick "cell phone" video to better explain my question.
VIDEO HERE:
View My Video
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: B Body Fuel Line Install Question [Re: BigDaddy440] #1305193
09/17/12 10:52 AM
09/17/12 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don't expect the fuel line to fit perfectly , a tweak here and there is expected . I have always seen the bigger ling against the floor pan ?
Re: B Body Fuel Line Install Question [Re: BigDaddy440] #1305194
09/17/12 12:18 PM
09/17/12 12:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
From my experience, only the suction and vent line go into the bolt on clips and then the return is held to the other lines with s hooks.
Not sure if this is correct and original but it's the way mine went on.
