High compression in a 400 BB on a budget? #1304827
09/16/12 04:01 PM
09/16/12 04:01 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I know the 400 has a bigger bore but if my calculations are correct I can use a low compression 440 piston in a .060 over size in a 400 with a smaller oversize and with the added compression height I could really bump the compression on an budget 400. Am I missing something?
I was also trying to come up with a way to use a LY rod in a 400 to get the compression up but I keep comeing up with the piston too far out the deck, is there an off the shelf piston for this scenario?
I already have 516 heads with big ex valves and some minor bowl work and milled .010 but compression ratio is still pretty low.
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304828
09/16/12 04:11 PM
09/16/12 04:11 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
ill be watching this 1
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304829
09/16/12 04:13 PM
09/16/12 04:13 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
KB has a set of pistons. What comp are you shooting for? Low comp 440 pistons would prob smack the valves in a 400
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304830
09/16/12 04:27 PM
09/16/12 04:27 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
These are the KB's
Amazon
Summit
Re: High compression in a 400 BB on a budget? [Re: mopar400] #1304831
09/16/12 04:32 PM
09/16/12 04:32 PM
Kalispell Mt.
Kalispell Mt.
I am hopeing for around 10 to 10.5 to 1
The 440 pistons are so thick it would not hurt to cut a couple valve notches in them. They would still be around .020 below deck. I could easily do valve notches here at the shop.
I already have a nice used set of the 440 .060 over pistons. I do not want to buy pistons unless I could get them real cheap and be able to use the long rods since long rods help a restricted head turn a little more RPM.
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304832
09/16/12 04:45 PM
09/16/12 04:45 PM
SoCal
Brian Hafliger Offline
SoCal
Brian Hafliger
Re: High compression in a 400 BB on a budget? [Re: Brian Hafliger] #1304833
09/16/12 05:06 PM
09/16/12 05:06 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
http://www.carcraft.com/techarticles/ccrp_1207_chrysler_b_series_400_hemi_power_at_half_the_cost/
Hopefully something in here can help!
Brian
I would be leery of using any of their suggestions, they can't tell the difference between a big block and a small block.
Danny
Re: High compression in a 400 BB on a budget? [Re: gofish] #1304834
09/16/12 05:16 PM
09/16/12 05:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Brian
Danny
Hmmmmm. I like the article on a couple of levels.
Re: High compression in a 400 BB on a budget? [Re: gofish] #1304835
09/16/12 05:19 PM
09/16/12 05:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Brian
Danny
Danny do you realize that the person that put up that link is the builder in that article ?
Re: High compression in a 400 BB on a budget? [Re: gofish] #1304836
09/16/12 05:25 PM
09/16/12 05:25 PM
SoCal
SoCal
Brian
Danny
Yeah, they got one photo wrong...some guys just have to pick things apart I guess.
Anyway, if it helps great if not, all well!!
Brian Hafliger
Re: High compression in a 400 BB on a budget? [Re: Brian Hafliger] #1304837
09/16/12 05:41 PM
09/16/12 05:41 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
Open mouth, insert foot!
Brian, if I offended you, I am sorry. I gave up on reading most car magazines years ago due to their attitude that most readers will believe anything they see in a magazine.
Because of the lack of budget pistons for the 400, you might as well break down and buy one of the cheaper stroker kits.
Danny
Re: High compression in a 400 BB on a budget? [Re: gofish] #1304838
09/16/12 07:03 PM
09/16/12 07:03 PM
SoCal
SoCal
Danny
I understand, and agree that magazine articles can be very misleading. That's why I try to help with the editing to make sure they print .010 instead of .100!
I hope the few articles we've been a part of are helpful to those that read them. That's super important to me and my dad. I try to make sure everything that goes into a build makes it into print so anyone trying to replicate the build can do it easily.
I know it's hard to appease the masses but we do try and give as much info as possible.
I do try to keep our builds realistic and hopefully that comes through!
Brian
Brian Hafliger
Re: High compression in a 400 BB on a budget? [Re: Brian Hafliger] #1304839
09/17/12 03:28 AM
09/17/12 03:28 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have done that. Using the low CR piston you end up with a piston about .020" below the deck at TDC. With a 80cc head nad a .040" head gasket you'll have around 9.8:1 The 66-71 piston will give you about .040" positive deck, that's what we used (TRW L2266 F) With open chamber heads close to 90cc and huge valve pockets we had a little over 10:1, had to form the piston tops slightly to fit the chambers. It worked actually pretty well, but nowadays that there are lighter HC pistons readily available, I doubpt that it is very cost effective.
Plynouth VIP '67 TT IC EFI
Re: High compression in a 400 BB on a budget? [Re: jyrki] #1304840
09/17/12 10:11 AM
09/17/12 10:11 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yeah IIRC the 2266 (TRW 70-72 piston) should be close (6.36" 383/400 rod) but you better check your skirt to CW clearance (it's been over 20 yrs since I done one like that). Whack about 1/2-5/8" off the length of the pressed 1.09" pins and you'll save ~45 grams on each slug and still have plenty to do the job, that's an old Dick Landy BB trick.
There's no way (I am aware of) to use a 6.76" rod with a factory 400 or 440 size mopar slug for this scenario. And I've built most of the Frankenstein variations over the yrs.
A bit of 'inverse' trivia....Mopar settled for the 4.15" RB Stroker crank length because it allowed for the use of a standard 4.342" 400 piston compression height.
After all the math was cyphered and done...just building a decked 383 using the taller 68-69 HP pistons with 67 Magnum closed chamber heads were a lot cheaper (and quicker) than the 400's. That was way before the reasonably priced KB's which is definately the way I'd go these days
Brian's magazine combo is excellent, I'd just use the '67 heads and I think the Crower 32242 is the perfect 383/400 cam.
WIZE
In Car:
Re: High compression in a 400 BB on a budget? [Re: gofish] #1304841
09/17/12 10:25 AM
09/17/12 10:25 AM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Danny
I ended up buying the stroker kit. I was really wanting to build a 400 with higher compression and almost purchased the KB pistons. I ended up needing a crank and some other parts and couldn't justify the cost. If I had a machine shop I would definetly build something like original poster is talking.
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304842
09/17/12 11:44 AM
09/17/12 11:44 AM
AndyF Online content
AndyF  Online Content
I did a low cost high compression 400 engine years ago for one of the magazines. The trick was to use Hemi rods and a shelf stroker piston. Worked great.
Re: High compression in a 400 BB on a budget? [Re: mopar400] #1304843
09/17/12 11:57 AM
09/17/12 11:57 AM
Kalispell Mt.
Kalispell Mt.
Are you kidding about the stroker kits? I don't see any stroker kits under $2000
Stroker VS what I have both need a bore job and gaskets so all that is a wash.
Useing what I got only costs me a balance job and the $2K kits need that checked anyhow.
I have some 383s sitting here but no good high compression pistons. Plus I figure the extra cubes and less shrouded valves has got to help the 400 run a little stronger.
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304844
09/17/12 01:52 PM
09/17/12 01:52 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
I didn't have enough good used parts laying around to use without work. I prefered to spend the $2000 for the kit. By the time I had a crank machined, balanced, bought new KB pistons, bearings, rings for the 400 it was a good bit of money. So far everything has checked out good on the stroker parts, I pick up an extra 50 cubes and I have no extra machining to make it work. Just a bore and hone. Some day I would still like to do a 400 cube motor with higher compression but it just wasn't a good move for me this time. I also have a very light rotating assly. with the stoker compared to the factory stuff.
Re: High compression in a 400 BB on a budget? [Re: AndyF] #1304845
09/17/12 03:22 PM
09/17/12 03:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is a great way to do it but the problem now is that hemi rod , I'm going to ASSuME 6.965 , is no longer available. 6.860 is the longest hemi spec rod available now .
Re: High compression in a 400 BB on a budget? [Re: HotRodDave] #1304846
09/17/12 08:35 PM
09/17/12 08:35 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Yep, i've done it. Used the 72-78 440 replacement pistons. .060 in a .040 400 block. The engine was a real budget build so i used cheap Badger cast pistons. If you already have the pistons, go for it.
