E body, where to run oil pressure line? #1304804
09/16/12 02:40 PM
09/16/12 02:40 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
I'm going to run mechanical oil pressure and electric temperature guages on my 71 Challenger along with the factory guages, at least until I can determine if the factory guages work and are accurate.
So where is a good place to run my plastic oil pressure line and my electric temperature guage wire through the firewall without drilling any new holes?
Thanks.
Re: E body, where to run oil pressure line? [Re: KillerBee] #1304805
09/16/12 02:58 PM
09/16/12 02:58 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello! First, don't use the plastic junk that comes with an aftermarket gauge kit. Go to NAPA or someplace like that and buy the copper tube kit for the oil pressure gauge. Comes cut to fit. Much safer! I ran mine thru the speedo grommet. Jeff
Re: E body, where to run oil pressure line? [Re: 1969RR] #1304806
09/16/12 04:09 PM
09/16/12 04:09 PM
scratchnfotraction Offline
x2
but I have run the plastic line thru some vac hose as a sheild to protect the fragile line more than once.
I did use a rubber groumet thru the firewall with the rubber vac hose also.
