oil pan pickup usage #1304734
09/16/12 11:54 AM
09/16/12 11:54 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
On the late '60 and '70 big block oil pickup screen, which pans
use the straight and which ones use the dog leg shaped one?
I have 187, 402 and six pack(564)pans I would like to match with
the correct pickups.
Re: oil pan pickup usage [Re: demonH1B] #1304735
09/16/12 05:10 PM
09/16/12 05:10 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
187 and 6 pack use straight , 402 uses the bent one .
Re: oil pan pickup usage [Re: JohnRR] #1304736
09/17/12 12:52 PM
09/17/12 12:52 PM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Thanks, I was thinking that way.
