Need help with choosing headers
#1303432
09/13/12 07:25 PM
09/13/12 07:25 PM
Posts: 258 Stockholm, Sweden
TomsCharger70
Stockholm, Sweden
New engine, a 493cid (440 block) with Indy EZ "Little Easy" 295 CNC heads. Cam lift .700. Engine will see 7000+ Rpm. Engine is built for Nitrous Oxide, will be using a 200Hp shot of Nitrous. Which headers to buy??? The 2" TTi440-200 OR 2 1/8" Step 400IB-218 headers??? Thanks /Tom
Re: Need help with choosing headers
[Re: TomsCharger70]
#1303434
09/13/12 10:13 PM
09/13/12 10:13 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
/Tom
I hope you aren't using a stock block???
[Re: TomsCharger70]
#1303435
09/14/12 02:30 AM
09/14/12 02:30 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
Mr P ran his header program for me for my 526 C.I. motor, it called for 2.201 diameter on the frist step primary pipe, 15 inches long and 2.326 diameter on the second step 15 inches long into a 4.0 inch collector 16.0 long Where going to use a 2 1/8 first step with a 2.250 second step with the 4.0 inch collectors IHTHs
[Re: Cab_Burge]
#1303436
09/14/12 04:08 AM
09/14/12 04:08 AM
TomsCharger70
Stockholm, Sweden
-Yes! Using aluminum main caps and light weight rotating parts.. and if it blows, it blows... then again I do think that something else in the engine will let go way before there is any problems with the block itself, though I do plan on upgrading to an aftermarket block later on.. just to give everyone out there a peace of mind
Did a little search about "Step" headers, seems that there is no real proof of advantage using them... So Im gonna go with the 2" headers.. If I loose a few Hp because of that I will not be sad about it...
/Tom
[Re: TomsCharger70]
#1303437
09/14/12 08:19 AM
09/14/12 08:19 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Tom my friend, step headers work. And it's not easy to figure it out without a ton of knowledge or a good header program. I choose headers from Performance Welding as they have the know how and make the best headers. If you are going for all out performance a good set of headers is a must. Just my
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: TomsCharger70]
#1303438
09/14/12 01:19 PM
09/14/12 01:19 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
/Tom
I hope it holds together for you, you just hear so many horro stoires. Sounds like it will get the job done.
[Re: Cab_Burge]
#1303440
09/14/12 08:53 PM
09/14/12 08:53 PM
TomsCharger70
Stockholm, Sweden
Just my
I did not say you couldnt make more power using Step headers, guess many things plays part. My opinion about them, from what I read and little knowledge I have about them, is that for the couple of times a summer racer its just not worth the hassle and money to go with custom made headers when you have such good headers from TTi. I also do NOT believe that the horsepower gain is that impressive, if you make 20 Hp more with step headers, well I do not think youll notice it much, well perhaps if you race a Pro Stocker...
All the NHRA stock and SS racers as well as some Comp Elininator racers say step headers are worth a little bit of power, ET and MPH on there race cars I seem to remeber someone dyno testing step versus straigh pprimary pipes of the same size as the first step and the steps worked better. The first motor I built and dyno tested made a lot more HP and torque going from a set of Hooker A body fenderwell headers with 1 7/8 primaryys and 3.5 inch collectors to a set of dyno headers thet dyno owner and operator made while my motor was on his dyno, he made them with 2 1/4 primary pipes and 4.0 collectors That motor was a 426 Max Wedge pump gas street motor with 9.5 to 1 compression on CA pump gas back in 1991 or 1992, it was for one of Boyd Coddington cars. That motor made more torque and HP all the way from 3000 RPM up to 6500 RPM when we quit pulling it there as it made peak HP at 5900 to 6100 RPM, depending on the changes we made to the tune up.
Again, how much more horsepower did that engine make with the larger size Step headers?? IF it made about 20 more, well -Sorry, Im not impressed... If you say it made more than lets say 50Hp more, then Ill call and say BS! If it made more than 50, damn that engine was denied breathing.. But I still dont buy it that it made more power just because the headers were step headers, if you had used a set of larger diameter headers my guess is that the power gains would have been about the same..
/Tom
[Re: TomsCharger70]
#1303441
09/14/12 09:17 PM
09/14/12 09:17 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I think the Wallace Calculators has a header sizing program on it.
I'm using a 2" header with a 4" collector on my small block. When I ran the program it came out real close to what I already have on there. I think you'd be better off with a larger tube.
[Re: Guitar Jones]
#1303442
09/14/12 09:52 PM
09/14/12 09:52 PM
TomsCharger70
Stockholm, Sweden
-Header tube or collector???
[Re: TomsCharger70]
#1303443
09/15/12 08:35 AM
09/15/12 08:35 AM
Guitar Jones
Tube size. Is this going in a B body? I think Hooker makes a super competition 2 1/8 primary tube size with a 4" slip fit collector.
