Page 2 of 3 1 2 3
Re: WIRING NIGHTMARE............................ [Re: topside] #1303205
09/15/12 06:41 PM
09/15/12 06:41 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
From a post on a Dakota Forum:
"Most technical standards prefer a crimped and strain relieved connection because it's generally the most idiot proof. If the wires are properly stripped and fully inserted, and IF the correct connector is used the with correct ratcheting crimper, then the connection is gas tight so corrosion won't be an issue. The strain relief built into the connector prevents the wire from flexing and breaking off at the crimp point.
Soldering on the other hand is not idiot proof and the connection even if properly soldered is often not strain relieved. Most solder connections typically have way too much solder and if it's not a cold solder joint the solder wicks too far up the wire strands, past whatever strain relief of heat shrink tubing. Then when the wire is flexed, the strain is applied at the end of the solder wicking allowing the wire to break. If you can't see all of the exterior wire strands, it's too much solder and if it's not smooth and shiny like chrome, it's a cold solder joint."
I crimp everything now WITH the right tool, and shrink wrap the connection. If you can solder like a pro, do it if not...Crimp.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303206
09/16/12 01:45 AM
09/16/12 01:45 AM
State of confusion
Thumperdart Offline OP
State of confusion
Just thinking out loud here but couldn`t I go take a high end fuse panel out of a modern car that is already equipted w/new style fuses and relays and go from there? Not being cheap but some factory stuff is as good as it gets from what I`ve seen working on these things.............
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303207
09/16/12 02:59 AM
09/16/12 02:59 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would just use some fuse blocks added to the factory wiring. This will be the most straight forward approach for the beginner. Run the lights, etc on the original stuff and run the aftermarket stuff (ignition, fuel pump, etc) on relays that get power from fuse panels. I think this will also be the most economical way as well.
Re: WIRING NIGHTMARE............................ [Re: 340B5] #1303208
09/16/12 04:01 AM
09/16/12 04:01 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Another thought; Make yourself a wiring diagram when you do re-wire. You'll thank yourself later.
I had a fellow that would wire street rods and race cars in my shop. I have never seen one of his neatest methods used by anyone else.He designed and laid out the the harness on a full sheet of peg board. The board had units to be wired in a location close to the finished project. That allowed him to then bundle the wires and keep it all very clean. When done it was transfered to the car .It was alost a perfect fit.
home of the
Sox and Martin Hemi Duster
Re: WIRING NIGHTMARE............................ [Re: HEMIFRED] #1303209
09/16/12 11:29 AM
09/16/12 11:29 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Thumper I rewired my car a few months back. I used the 12 mini circut from this site. http://www.ezwiring.com/wiring_harness.html
Re: WIRING NIGHTMARE............................ [Re: Twin Turbo Mower] #1303210
09/16/12 12:02 PM
09/16/12 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That looks like a decent kit.... I have about $200
invested into mine BUT I have plenty of wire left over
on spools for other projects
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Jeremiah] #1303211
09/16/12 01:06 PM
09/16/12 01:06 PM
State of confusion
State of confusion
Thankxxx again........ Those kits look awesome as well as clean and easy to install. I`ll figure it out soon and go from there........... peace!
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303212
09/16/12 03:22 PM
09/16/12 03:22 PM
in the middle
dodger mope Online content
dodger mope  Online Content
in the middle
dont forget the salvage yard,their is some great used electrical centers priced dirt cheap in those later model cars.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: dodger mope] #1303213
09/16/12 03:37 PM
09/16/12 03:37 PM
State of confusion
State of confusion
That`s what I posted earlier and is still an option.........
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303214
09/16/12 07:02 PM
09/16/12 07:02 PM
Delray beach, Florida
P
Performance Only Offline
P
that sounds like the best option IMO. i don't know why more people don't do it. the late model OEM fuse boxes are hard to beat.
machine shop owner and engine builder
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Performance Only] #1303215
09/16/12 07:57 PM
09/16/12 07:57 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
For one reason; There are multiple microprocessors in the fuse center. It is known as Body Control Module A. Or at least it is on the wifes Nitro.
I'm not so sure how those processors would work on an old fashioned wiring set-up. You might want to talk to an experienced Chrysler tech/electrician first.
Yeah, it's got a smallblock.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: 340B5] #1303216
09/16/12 08:07 PM
09/16/12 08:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Most new fuse boxs are know as TIPM or TIPMCGW they have FCM in them. Not good for a race car . Beside I have to replace 1 every two weeks because they go bad. they have modules in them to control alot of stuff. FCM=front control module TIPM = totally intergrated power module. TIPMCGW=totally intergrated power module central gateway module. beside you would need a wiring dailgram with a connector pin out and the connectors to use one.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: VernMotor] #1303217
09/16/12 08:26 PM
09/16/12 08:26 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
When I put one on the wifes Nitro there were 111 on back order w/ 88 spoken for
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: 340B5] #1303218
09/16/12 08:28 PM
09/16/12 08:28 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Nitro is the bad one. I have replace 6 of them so far.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: VernMotor] #1303219
09/16/12 09:28 PM
09/16/12 09:28 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The first thing to do would be make a list of things that need power. At that point you can decide on what can share a home run to the fuse box and what needs a relay and so on to figure out how many circuits you will need.
The main reason for running some of the original harness is to reuse the connections for the steering column, body/light wiring, w/s wipers (if you have them), etc. At that point you can clean up the wiring you have added on by landing the (+) side to an ATC fuse block that is powered from your existing Ford relay. I bet I could rewire the car for less than $100 that way. It would be nice, functional, and easy to troubleshoot or add additional circuits.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Jeremiah] #1303220
09/17/12 12:40 PM
09/17/12 12:40 PM
State of confusion
State of confusion
Well then get your azz over here and I`ll even buy you lunch and beers. I`m a bit lost on the newer junk yard model boxes and the associated issues you guys mentioned. My thaught was to rob the box and the relays and newer fuses and tie it into my wiring loom....... Can`t I isolate/remove those thingies and go from there? Thankxxxx..............
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303221
09/17/12 01:12 PM
09/17/12 01:12 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
With self reseting circuit breakers at about $2 each, or an 8 circuit ATO/ATC fuseblock for about $12 plus fuses, and only about $5 per relay/base/term pkg, I really don't see much of a cost savings by buying a used junkyard fuseblock. You can tailor your electronics to do exactly what you want, without having to figure out the quirks of a factory board.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Evil Spirit] #1303222
09/17/12 05:31 PM
09/17/12 05:31 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I just bought one on these at 6 inches by 4-1/2 it is compact and worth it to me.
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: RADAMX] #1303223
09/18/12 10:36 PM
09/18/12 10:36 PM
State of confusion
State of confusion
Just so we all know, how much does this piece cost...........thankxxx
Re: WIRING NIGHTMARE..............NEW IDEA! [Re: Thumperdart] #1303224
09/18/12 10:40 PM
09/18/12 10:40 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Page 2 of 3 1 2 3
