Re: 78 D-150 No headlights.
[Re: elmor]
#1303074
09/12/12 09:20 PM
09/12/12 09:20 PM
Posts: 5,110 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Check the wiring around the high beam indicator button on the floor, and make sure its plugged in all the way.
...FAFO...
[Re: skicker]
#1303075
09/12/12 11:06 PM
09/12/12 11:06 PM
Posts: 6,022 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I agree, that'll do it (cause them to NOT work)
good luck! Otherwise, wiring issue somewhere, ground, relay, etc.
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: elmor]
#1303076
09/13/12 09:37 AM
09/13/12 09:37 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
If the relay is clicking you have a short somewhere.Do the tail lights come on when you turn on just the park lights?Try taking the connectors off the headlight bulbs.Ive seen the bulbs go bad and short inside.If it still kicks out the HL relay there is a short in the wiring.Un bolt the hi beam switch from the floor and see if it kicks out.Ive also seen the wiring to it ground on the floor.Rocky
Chrysler Firepower
[Re: Paul_Fancsali]
#1303078
09/14/12 05:19 PM
09/14/12 05:19 PM
therocks
Niles , Ohio
A missing ground will either have the lights dim or not working.It wont make the HL relay kick out.Something in the curcuit is shorted to kick it outRocky
Chrysler Firepower
[Re: elmor]
#1303082
09/16/12 06:00 PM
09/16/12 06:00 PM
RapidRobert
tail lights and parking lights are the same small filament in the 1157 bulbs. This circuit originates in the headlight switch. Could pull the connector off of the headlight switch & jump fire to the correct female terminal in the connector & see if they light up. If not go downstream to the next connector & check it for fire (might be behind the drivers kick panel). keep working your way rearward & checking each connector for the open
