Re: Piston to Deck Calculations
[Re: elmor]
#1303063
09/12/12 08:42 PM
09/12/12 08:42 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yes
block height - compression height - Rod length - 1/2 stroke = - number will be positive deck
so 10.725 - 2.060 - 6.768 - 1.875(1/2 3.75) = .022
[Re: Cab_Burge]
#1303066
09/13/12 12:44 AM
09/13/12 12:44 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Myself no matter how many times I do the math I am never satisfied until I assemble the shortblock and check it. And it makes you feel smart when you got it right. Ron
[Re: elmor]
#1303068
09/13/12 07:00 AM
09/13/12 07:00 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I'm asking because I want to gather some info to help me decide on pistons and heads to use. I'm going to build a mid 70's 360. I want to get 9.5 or maybe 10 to 1 compression. I was leaning towards KB 107's, my machinist is saying Sealed Power H116CP. It's going in an A-body, 727, 3.91 gears. I am looking to get 400 HP out of it and I know it can be done with the right parts fairly easily.
Sounds like you are asking the right questions at the right time.
[Re: Cab_Burge]
#1303071
09/13/12 08:32 PM
09/13/12 08:32 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
If your going to use a set of iron heads make (on Oregon 10 or 15% pump gas) your compression ratio under 9.5 to 1 If aluminum shoot for max of 10.5 to 1
Right across the border in Idaho several of our local gas stations have been offering Ethanol-FREE super unleaded. It's fairly popular with the powersports crowd so I hope they keep it around for a while
[Re: elmor]
#1303072
09/13/12 09:47 PM
09/13/12 09:47 PM
RapidRobert
I'm asking because I want to gather some info to help me decide on pistons and heads to use. I'm going to build a mid 70's 360. I want to get 9.5 or maybe 10 to 1 compression. I am looking to get 400 HP out of it.
I'd have the crank turned & get your bearings and bore/hone and square deck it then mockup a rod/piston & see what you're deck height is. May need decking again or the correct or custom $Cometic$ head gaskets. I would absolutely shoot for .040" quench on every hole. Alot of work/expense but right is right and you're after some good power and fuel is so poor these days. (1) decide on the octane you will be using (2) decide how much cam you are willing to tolerate. (3) set the SCR to match (1) and (2) & leave room to run a fast dist curve. You could check heights in all 4 corners then deck to square the appropriate amt all in 1 shot but I prefer to have everything square/parallel/plumb before I start measureing especially since I want my quench perfect in each hole & less chance for measuring errors anywhere else along the way. EDIT Magnum heads
