Page 3 of 4 1 2 3 4
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302553
10/11/12 08:23 PM
10/11/12 08:23 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Close up of chamber/seats
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302554
10/11/12 08:27 PM
10/11/12 08:27 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
As cast intake port.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302555
10/11/12 08:31 PM
10/11/12 08:31 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
With my CNC program this is the largest port I have put in W9s yet.
1.405 * 2.225
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302556
10/11/12 11:11 PM
10/11/12 11:11 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
soon
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: High end W9 head build up start to finish. [Re: WHITEDART] #1302557
10/11/12 11:21 PM
10/11/12 11:21 PM
Toronto
mshred Offline
mshred  Offline
Toronto
awesome stuff! subscribing!
Re: High end W9 head build up start to finish. [Re: mshred] #1302558
10/12/12 08:41 AM
10/12/12 08:41 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Can you say airflow.after this I think a lot of people will say w9 are a good head. I have a new set in the box that I will get done that I paid $500 for them I could be wrong but I don't think you can find a new set of w8 for $500
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302559
10/12/12 10:22 AM
10/12/12 10:22 AM
Out West
408strokerdart Offline
Out West
I don't know that I have ever heard anyone say that the W9 is a bad head. They just never got much of a chance to prove themselves because there wasn't any real development work done on them. The only highly developed ones were the RP versions that were done for the Sprints and work well for those applications. I think as more people see how much potential there is in these heads that they will be pleasantly surprised. It is basically just a lighter W8 and new castings are available.
Re: High end W9 head build up start to finish. [Re: 408strokerdart] #1302560
10/12/12 10:43 AM
10/12/12 10:43 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I have heard the RP is a real disappointment on gasoline, just doesnt do much if any better than the "standard" W9, but much better when on methanol. Who is casting the w9 now? I know Zeus is long gone.
Re: High end W9 head build up start to finish. [Re: 408strokerdart] #1302561
10/12/12 10:44 AM
10/12/12 10:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They took a W-7 and a W-8 and came up with a light
weight W-9.... like you said I never heard anything
bad on them... I like my W-9s(CNCd Chapmans), this
winter I'll put a cam in mine so its more in line to
what it needs... I'll see if they can re-grind my
current one or I might have to send my spare blank
in to get cut
Re: High end W9 head build up start to finish. [Re: MR_P_BODY] #1302562
10/12/12 11:41 AM
10/12/12 11:41 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
No I wasnt saying the heads are bad or junk.i always hear the w9 can't compare or out perform the W8 head
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302563
10/12/12 11:54 AM
10/12/12 11:54 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
BTW there's a guy on my Facebook that I've talked to once he has a 430 I think but it's has w9 heads 14.5 compression 760 roller stock Holley 1050 car weighs 2950. He said that it has 6 degrees less timing off the line because it either blows the tires or put it on the bumper. The car has a 315 DR tire if i remember right the 60 ft was a 1.19 and went [Email]5.52@125[/Email]
Re: High end W9 head build up start to finish. [Re: Otherlane] #1302564
10/12/12 12:12 PM
10/12/12 12:12 PM
Out West
Out West
Again, I give Brett a big on his effort. His port looks amazing and performs just as good. I can't wait to see what these heads do on the combo they are going on. I think they fill a much needed gap and should make alot of prople consider staying with SB power if they are looking for something in the 800 to 850 hp range.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302565
10/12/12 04:43 PM
10/12/12 04:43 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Brett, are these heads being done with Dennis Wheet? I am the kid from WI that sent my W9's out to Dennis to be ported with some new CNC program, just wondering if this is the program I'm getting. Also I'm still looking for parts to be able to use my heads. I know you have talked to my engine man Pete from CP Motorworks, if you come across anything let us know. Thanks -Dylan.
Re: High end W9 head build up start to finish. [Re: SpareParts] #1302566
10/12/12 07:00 PM
10/12/12 07:00 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Yes Dennis and I worked together on this port.
Your heads are close to this but they are 59* so pushrod pinch will be smaller on your heads and this is bigger program altogether than what was run in your heads.
Yes I have talked with Pete on your set up.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302567
10/12/12 08:56 PM
10/12/12 08:56 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Been ing over these. Can't wait to see the exhaust.
Yeah, it's got a smallblock.
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302568
10/15/12 11:23 PM
10/15/12 11:23 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Cool can't wait to see my stuff. Now I just gotta screw a motor together and go. . . hopefully fast lol
Re: High end W9 head build up start to finish. [Re: W5DART66] #1302569
10/28/12 11:33 PM
10/28/12 11:33 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Love the info..
Re: High end W9 head build up start to finish. [Re: Dos Snails] #1302570
10/29/12 03:31 AM
10/29/12 03:31 AM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: High end W9 head build up start to finish. [Re: Triple Threat] #1302571
11/02/12 12:06 AM
11/02/12 12:06 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
X2
Re: High end W9 head build up start to finish. [Re: Biginchmopar] #1302572
11/02/12 12:13 AM
11/02/12 12:13 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Sorry hope to have some update next week.;-)
Page 3 of 4 1 2 3 4
