Gen lll Hemi oil system mods #1302357
09/11/12 10:24 PM
09/11/12 10:24 PM
Burlington, Ontario Canada
Dave_S Offline OP
Dave_S  Offline OP
Anyone know what mods (if any) are neccesary to make a Gen III live in a race enviroment. They were alluded to in a previous post and also when I was quizzing a local Drag Pack owner. The S/S guy didn't want to give up his secrets, not that I blame him. If anyone has any insight I would appreciate the help. I dont really want to learn the hard way. I already have a forged rotating assy. and a high volume oil pump. I plan on keeping the rpm to 7500 max.
DAve
Re: Gen lll Hemi oil system mods [Re: Dave_S] #1302358
09/11/12 10:55 PM
09/11/12 10:55 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Good luck, many have asked the same question. Those that do know aren't giving up the info!
Alan Jones
Re: Gen lll Hemi oil system mods [Re: LA360] #1302359
09/12/12 09:11 PM
09/12/12 09:11 PM
Dave_S Offline OP
Dave_S  Offline OP
I guess your right. Those who know seem to be keeping it to themselves.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Gen lll Hemi oil system mods [Re: Dave_S] #1302360
09/13/12 09:35 AM
09/13/12 09:35 AM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Are you building a stroker engine?
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Gen lll Hemi oil system mods [Re: lowflyingdart] #1302361
09/13/12 10:38 PM
09/13/12 10:38 PM
Dave_S Offline OP
Dave_S  Offline OP
No stroker....a .020 over 5.7 with a 6.1 forged crank.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Gen lll Hemi oil system mods [Re: Dave_S] #1302362
09/14/12 12:24 AM
09/14/12 12:24 AM
MN
hemidup Offline
hemidup  Offline
MN
What oil pan you plan on using and how many qt's?
Jerry Williams.
Re: Gen lll Hemi oil system mods [Re: hemidup] #1302363
09/14/12 02:35 PM
09/14/12 02:35 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Keep the oil squirters, take the lip out of the oil pump where the pick up tube meets and get an accumulator. The HYD lifters will be fine.
That will be more than enough. These engines don't have oiling issues.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen lll Hemi oil system mods [Re: AlexP] #1302364
09/14/12 08:12 PM
09/14/12 08:12 PM
MN
hemidup Offline
hemidup  Offline
MN
Alex. He's building a 5.7. They don't have oil squirter's.
Let me ask a question. Lets say we have 2 oil pumps that produce the same amount of oil pressure at rpm. One being stock and the other a high volume. Here is the question. Would you rather have more oil in the heads or in the oil pan?
Jerry Williams.
Re: Gen lll Hemi oil system mods [Re: hemidup] #1302365
09/18/12 06:56 PM
09/18/12 06:56 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Thats a compromise. I'd like to have the valve train very well lubricated but dont want the springs drowning in it.
For most uses, I'd feel comfy with plan C...4 quarts in the sump (or draining down), 2 floating around up top and a qt in the accumulator just in case.
Re: Gen lll Hemi oil system mods [Re: AlexP] #1302366
09/18/12 07:53 PM
09/18/12 07:53 PM
IN
ahy Offline
ahy  Offline
IN
I think its a trick question... with the engine at speed and the same oil pressure, oil flow through the engine will be the same. The HV pump will just be dumping more out the bypass and back into the pan... and using a little extra power and heating up the oil more.
The main benefit of the HV pump is at low RPM/hot oil conditions where a stock pump may not make enough flow and pressure with increased bearing clearances.
Re: Gen lll Hemi oil system mods [Re: ahy] #1302367
09/18/12 08:43 PM
09/18/12 08:43 PM
Dave_S Offline OP
Dave_S  Offline OP
Thanks for the input guys. This web site has lots of good info as well: http://monstermopar.com/forum/index.php?board=43.0
Seems like the biggest problem is oil pump cavitation at higher rpm. The fix seems to be porting the inlet side of the pump and ensuring adequate drain back from the heads.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Gen lll Hemi oil system mods [Re: Dave_S] #1302368
09/19/12 04:38 AM
09/19/12 04:38 AM
MN
hemidup Offline
hemidup  Offline
MN
Good read. Barton is probably going with a K1 non cross drilled crankshaft. The problem is, is they were suppose to be available last March, then July and then when they showed up, they're ground with the wrong stroke??? Must be a communication problem between China and the USA lol. Most of the oiling issues with the factory 6.1 drilled crankshaft's are the #3, #4 rod bearings at high rpm. Never seen an issue with the #7,#8 which get's oil last.
Jerry Williams.
Re: Gen lll Hemi oil system mods [Re: hemidup] #1302369
10/11/12 11:38 AM
10/11/12 11:38 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Any new ideas..?
If you like drag racing, support your local track.
Re: Gen lll Hemi oil system mods [Re: CHAPPER] #1302370
10/11/12 05:01 PM
10/11/12 05:01 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I am not expert but play one on here.
My 6.1 storker has a stock oil pump and has plenty of PSI. (75PSI) I would not use a HV pump its not needed, I feel these motors already pump plenty of oil to the top end.
Make sure that the oil pan you use has the dimples in the pan rail and does not cover up the drain back holes in the rail of the block.
I am using a custom Charlies 7Qt pan with kick out and the factory oil pan gasket/windage tray.
Re: Gen lll Hemi oil system mods [Re: 340RICK] #1302371
10/11/12 07:14 PM
10/11/12 07:14 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Thanks Rick, but,that's all ya' got..?? I'm looking for MORE info. I've got/had ALL those things covered....still lost a #4 rod. The concensus/opinions of the people I have talked to, that have had rod failures,, all with #3 or #4 rod,, seem to think the crank is the problem. Don't want a pizzn match,, just trying to get some experienced opinions. I know that is hard here,, . I am talking oil problems in the 7500-7800RPM range. I don't know what anybody else is turning, but I was impressed with how these things rev. The motor was COMPLETELY upgraded internally...no stock stuff in it other than the crankshaft/block.
Re: Gen lll Hemi oil system mods [Re: CHAPPER] #1302372
10/11/12 08:56 PM
10/11/12 08:56 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Dont Pizz me off
I am running a Manley 4.050 crank
I have had my 6.1 to 7500RPM many times and its still pulling, been to chicken to go any higher. I am running more camshaft than the drag pak motors, with ported heads so I would assume mine would like some more RPM, but on dyno and at track I have shut it down at 7500rpm so far.
I am going to pull pan off my motor this winter and take a peaky poo at the rods and mains just for safety sake.
I have a system one filter on since day one and its been clean as a whistle and I check it often. I also have a oil temp guage in car as well and it stays fully warmed in the 170-180 range max
Re: Gen lll Hemi oil system mods [Re: 340RICK] #1302373
10/11/12 11:07 PM
10/11/12 11:07 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
....there it is...the secret to success...MANLEY CRANK...I knew it!!!
Re: Gen lll Hemi oil system mods [Re: CHAPPER] #1302374
09/13/13 07:15 PM
09/13/13 07:15 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I like to bring this topic up again for an issue I just noticed with my 5.7Hemi.
Looking at/into the oilfilter mount, I noticed 2 little holes in the casting, alongside the inlet-port into the oilfilter.
The side holes were formed because the casting was thin enough there to break away.
Some gentle poking caused the edges of the holes to chip away some more very easily.
I've enlarged and camfered one of the holes into the inlet-port and plan to do the same with the second hole.
If I'm correct this is the pressure-side of the pump, right before the oil goes into the oilfilter.
First pic shows the as-found situation.
Second pic shows the modified situation.
Third pic shows the remaining castinghole I plan to open up and blend into the filter area.
Any thoughts?
"Original"
"Modified"
Other casting hole;
Re: Gen lll Hemi oil system mods [Re: 340RICK] #1302375
09/16/13 10:00 PM
09/16/13 10:00 PM
SC304 Offline
SC304  Offline
I currently run a NHRA SS 6.1 motor with the factory crank. It has been reworked and treated. I run a high volume pump with any of the K-1, Callie's or Molnar rods. I do run Jesel dog bone lifters and a cam over .800 lift with Jesel rockers. With these lifters which we modify we Run bushings to control oil up top. We spin 8200 to 8800 depending on gear / converter Combo. Been 9.35 @ 144 at 3400 lbs with no issues. We run a custom Moroso oil pan with a full kick out short of the K&N filter mounted in the stock location. We have also smoothed out the inlet and outlet on the filter mount.. I have not noticed any pin holes in the castings in the area of the filter but we have only ground on 6.1 blocks. Just my personal observations.
Re: Gen lll Hemi oil system mods [Re: SC304] #1302376
09/16/13 10:29 PM
09/16/13 10:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
So the 6.1 crank is proven to oil good up to 7500-8000 ok? When the Drag Pack first were speced out they said stock cranks?? Heres mine I was messin with last night.
Mopar to the bone!!!
