Got a set of their roller rockers . The shafts and hold downs are drilled .400" , very large holes for the stock 5/16" hold down bolts . Do they require the rocker shaft stands to be drilled and tapped for 3/8 bolts??? Will be using on j-heads then switching to edelbrock heads later .
