My luck ran out ..... #1302216
09/11/12 07:07 PM
09/11/12 07:07 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Went racing last week and hurt the trans .
First pass it launched a few feet and unloaded the tires and spun REAL good ..then hooked so i ran it out to a blistering 10.40
Next pass I put a 3K chip in it to calm her down a bit, let go of the button and it launched about 2 feet and ZINNNGG !! up on the 7K chip. For a split second I thought it just boiled the tires.... then realized the car wouldnt move.
So i went to 2nd and then 3rd drove it back.
No 1st gear , but I have everything else.
My guess is my fancy bolt in sprag let her bits n pieces loose.... Yes ?
I was just getting ready to order a ladder bar kit too..
Re: My luck ran out ..... [Re: 493_DART] #1302217
09/11/12 07:40 PM
09/11/12 07:40 PM
Guitar Jones Offline
You may have broken something in the geartrain.
Re: My luck ran out ..... [Re: 493_DART] #1302218
09/11/12 08:54 PM
09/11/12 08:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You got a billet drum in that? If not it should have put the dash thru the windshield. If it is a stock one it is definitely time to retire it as I'm sure it is full of stress cracks now .
Can a billet one be put back in service after turning 27 bazillion RPM?
Kevin
Re: My luck ran out ..... [Re: 493_DART] #1302219
09/11/12 09:42 PM
09/11/12 09:42 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Launching, spinning and then Hooking is what kills ANY roller clutch.....
If you can't handle the truth, you're living a lie.......
Re: My luck ran out ..... [Re: Big Squeeze] #1302220
09/11/12 09:55 PM
09/11/12 09:55 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I always worry about this with my 727. I assume it has a manual valve body with no low band apply. I hurt my last trans this same way and it had a bolt in sprag. just busted the case to turn the sprag.
67' charger 499 RB 10.57 at 127
Re: My luck ran out ..... [Re: dragram440] #1302221
09/11/12 10:06 PM
09/11/12 10:06 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Yep...im scared of the drum now....
the vb is not a low band apply . so the low band vb will save the sprag from blowin chunks ?
Re: My luck ran out ..... [Re: 493_DART] #1302222
09/11/12 10:20 PM
09/11/12 10:20 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I agree. The best thing would be to buy a good drum. Dont lift in first gear.
Re: My luck ran out ..... [Re: 493_DART] #1302223
09/11/12 11:10 PM
09/11/12 11:10 PM
tboomer Offline
tboomer  Offline
I was sorry to hear that on Saturday,Kevin. You will be up and going in no time!
Re: My luck ran out ..... [Re: tboomer] #1302224
09/11/12 11:36 PM
09/11/12 11:36 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
He better be. Doesn't he have a race coming up against another MOPARTS member.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My luck ran out ..... [Re: pittsburghracer] #1302225
09/11/12 11:38 PM
09/11/12 11:38 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Hehee.........we called it off... unless I hit the lottery tomorrow...
Re: My luck ran out ..... [Re: pittsburghracer] #1302226
09/11/12 11:40 PM
09/11/12 11:40 PM
tboomer Offline
tboomer  Offline
John...I parked my car..Hung up the helmet!!
Re: My luck ran out ..... [Re: 493_DART] #1302227
09/12/12 10:32 AM
09/12/12 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which FANCY bolt in sprag did you have ?
Re: My luck ran out ..... [Re: 493_DART] #1302228
09/12/12 10:41 AM
09/12/12 10:41 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes. A bolt-in sprag w/o a LBA valve body is a waste of money.
Re: My luck ran out ..... [Re: slantzilla] #1302229
09/12/12 01:55 PM
09/12/12 01:55 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
John --cant remember, id have to ask my tranny guy , could have been A&A since I have one of their stickers sitting here ?
slant--im already shopping --the Griner looks good
Re: My luck ran out ..... [Re: 493_DART] #1302230
09/12/12 01:57 PM
09/12/12 01:57 PM
tboomer Offline
tboomer  Offline
Sold any Marshall amps lately?
Re: My luck ran out ..... [Re: tboomer] #1302231
09/12/12 02:16 PM
09/12/12 02:16 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
yEP--And they guy completely flaked out of $650. I had to relist it today.
Ebay is the new Craigslist...total freakshow ,buyers can do whatever they want.
Re: My luck ran out ..... [Re: 493_DART] #1302232
09/12/12 02:20 PM
09/12/12 02:20 PM
tboomer Offline
tboomer  Offline
That is what scares me.. If ya have it ready for Mopar Max...I may get my junk outta storage....
Re: My luck ran out ..... [Re: 493_DART] #1302233
09/12/12 02:32 PM
09/12/12 02:32 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Broke the sprag like that 2 times. One was a bolt in sprag that uses the stock parts. Those little metal tangs still fold over easy from the rollers. I now have the a&a ultimate sprag as they call it in my trans along with a griner valve body low band apply been running that for a few years now. The ultimate sprag is a more heavy duty peice. Would be interesting to see which one you had.
Re: My luck ran out ..... [Re: Twin Turbo Mower] #1302234
09/12/12 02:40 PM
09/12/12 02:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
When i read the thread title, i thought your engine had gone bang.
Kevin, i fitted an A & A VB with LBA, after the last time i broke the sprag.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: My luck ran out ..... [Re: 493_DART] #1302235
09/12/12 03:42 PM
09/12/12 03:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Direct hookup to Griner right here:
http://www.727specialist.com/index.html
