My luck ran out .....
#1302216
09/11/12 07:07 PM
09/11/12 07:07 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Went racing last week and hurt the trans . First pass it launched a few feet and unloaded the tires and spun REAL good ..then hooked so i ran it out to a blistering 10.40 Next pass I put a 3K chip in it to calm her down a bit, let go of the button and it launched about 2 feet and ZINNNGG !! up on the 7K chip. For a split second I thought it just boiled the tires.... then realized the car wouldnt move. So i went to 2nd and then 3rd drove it back. No 1st gear , but I have everything else. My guess is my fancy bolt in sprag let her bits n pieces loose.... Yes ? I was just getting ready to order a ladder bar kit too..
Re: My luck ran out .....
[Re: 493_DART]
#1302217
09/11/12 07:40 PM
09/11/12 07:40 PM
Guitar Jones
You may have broken something in the geartrain.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 493_DART]
#1302218
09/11/12 08:54 PM
09/11/12 08:54 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You got a billet drum in that? If not it should have put the dash thru the windshield. If it is a stock one it is definitely time to retire it as I'm sure it is full of stress cracks now . Can a billet one be put back in service after turning 27 bazillion RPM? Kevin
[Re: Big Squeeze]
#1302220
09/11/12 09:55 PM
09/11/12 09:55 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I always worry about this with my 727. I assume it has a manual valve body with no low band apply. I hurt my last trans this same way and it had a bolt in sprag. just busted the case to turn the sprag.
67' charger 499 RB
10.57 at 127
[Re: 493_DART]
#1302222
09/11/12 10:20 PM
09/11/12 10:20 PM
dragram440
bigfork mn
I agree. The best thing would be to buy a good drum. Dont lift in first gear.
67' charger 499 RB
10.57 at 127
[Re: 493_DART]
#1302227
09/12/12 10:32 AM
09/12/12 10:32 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Which FANCY bolt in sprag did you have ?
[Re: Twin Turbo Mower]
#1302234
09/12/12 02:40 PM
09/12/12 02:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
When i read the thread title, i thought your engine had gone bang. Kevin, i fitted an A & A VB with LBA, after the last time i broke the sprag. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
