pt cruiser timing belt #1301827
09/10/12 11:25 PM
09/10/12 11:25 PM
central illinois
65dodgebob Offline OP
central illinois
i need some advice! chance to buy a nice pt cruiser cheap, but has broken timing belt. do these motors have enough valve clearance to avoid damage or does everything crash when a belt breaks?
Re: pt cruiser timing belt [Re: 65dodgebob] #1301828
09/10/12 11:35 PM
09/10/12 11:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
According how fast the motor was spinning when it broke. Usually will bend a couple of valves.But if its cheap enough and a nice car go for it and get it fixed.
Re: pt cruiser timing belt [Re: 71birdJ68] #1301829
09/11/12 06:54 AM
09/11/12 06:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They dont usually bend valves.The valves actually hit each other depending on the RPMs.My wifes broke at about 25 MPH.New belt and WP and runs fine.They are a pain to change as its really tight in there.The exhaust cam has to be about 1 tooth off the timing marks when you set the cams.Rocky
Chrysler Firepower
