Camshaft / Exhaust Combo #1301721
09/10/12 08:53 PM
09/10/12 08:53 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Currently finishing up my 440 build. I want to reuse my factory hi-po manifolds from my roadrunner.
The two cams I'm looking at are the Lunati 60303 and 60304.
I've read on other posts here that guys ran the 60303 in low compression 440's but had headers. I want to run the 60304 since my 440 short block is running six pack pistons and higher compression.
Can I run the larger cam with hipo-manifolds and a 3 inch exhaust or is it not a good idea?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Camshaft / Exhaust Combo [Re: CurYellowBird] #1301722
09/10/12 09:58 PM
09/10/12 09:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What heads, and actual compression ratio?
Of the two, the 303 would be a better choice, if you don't have too much CR. If you have iron heads it might not run on pump gas. If you want a larger cam try Mr Six Pac or Dwyane Porter.
Re: Camshaft / Exhaust Combo [Re: CurYellowBird] #1301723
09/10/12 10:03 PM
09/10/12 10:03 PM
Kirkland, Washington
Pacnorthcuda Offline
The issue won't really be the Cam, as much as manifolds and a 3 inch system. You're just begging for DRONE. I bought my 'built' 440 Cuda with HP mannys and a 3 inch TTI system. Dynomax mufflers.
Excruciating drone.
Went to headers/2.5"/magnaflows (Dynomax would have been fine) NO drone.
I also run the 60303 Lunati.
Re: Camshaft / Exhaust Combo [Re: Pacnorthcuda] #1301724
09/10/12 10:09 PM
09/10/12 10:09 PM
San Antonio, TX
San Antonio, TX
The heads are 452's from Aero Head that have 2.14/1.81 valves. The heads were surfaced so probably close to stock cc. The short block is close to zero deck after going with L2355 flat tops.
Please define drone for me because I don't really know the term.
Re: Camshaft / Exhaust Combo [Re: CurYellowBird] #1301725
09/10/12 10:12 PM
09/10/12 10:12 PM
Its a resonance (think BUZZING) in the exhaust while your cruising at light-mid throttle. Often in the 40-60mph range.
Noise to the point of NO conversation in the car. VERY annoying.
3" pipes often contribute to it, and in my opinion 3" pipes connected to manifolds ASK for it.
My experience was brutal. Previous owner installed a 500W stereo to drown it out!!!
Re: Camshaft / Exhaust Combo [Re: Pacnorthcuda] #1301726
09/10/12 10:16 PM
09/10/12 10:16 PM
Your engine will be fine with either cam. BUT! Do you have an automatic tranny? Whats the converter? Do you have power brakes??? The 60304 could very well be a concern with power brakes.
Re: Camshaft / Exhaust Combo [Re: CurYellowBird] #1301727
09/10/12 10:19 PM
09/10/12 10:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Exactly how far down are the pistons, and what head gasket thickness? Were the heads cut?
You are probably around 9.5:1. If so, the 303 will be close with with 91 octane IMO.
Re: Camshaft / Exhaust Combo [Re: BSB67] #1301728
09/10/12 10:30 PM
09/10/12 10:30 PM
San Antonio, TX
San Antonio, TX
This is a 4 speed car with manual brakes.
With the piston at TDC, the ridge is barely enough for me to catch with a fingernail. I am not at my dad's so I can't give exact measurement. I'm using Felpro replacement head gaskets to try and keep the compression somewhat down rather than using steel shim gaskets.
Now I know what drone is. I've heard it before just never knew there was a name to it.
Re: Camshaft / Exhaust Combo [Re: BSB67] #1301729
09/11/12 12:11 AM
09/11/12 12:11 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I believe the distinction has been drawn that a Big Block Mopar with exhaust manifolds benefits from a cam center line somewhere around 112-to-114 and exhaust duration not much more than 284.
Andy Finkbeiner's dyno testing seems to confirm this as well as the track tuned Mr. 6Pack cam from Bob Karkashian.
So there again, the Mr. 6pack grind I decided to go with is optimized to run with bone stock 906 heads and HP manifolds. It's center line is 114 and has exhaust duration somewhere in the ballpark of the stock Magnum/Road Runner cam ~ 284.
Re: Camshaft / Exhaust Combo [Re: CompSyn] #1301730
09/11/12 12:19 AM
09/11/12 12:19 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have run the 60303 as well. First question, what is your rear gear ratio?
I ran the 60303 in a smogger 440 with headers, 440 source heads and 3.55 gears with a stock converter. It really needed more converter and would have liked more gear because of the lack of compression.
