1/2" oil pickup or external to pan? for a 400b 470 #1300914
09/09/12 09:13 PM
09/09/12 09:13 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
i have been collecting parts for a hopefully strong pulling engine.
now they change the rules for street stock to 470cid.
so a long time ago i got jake zareings 440-1c heads to buile a big block to kick some ford and chevy ass. well times and rules have changed.
i am going 400b engine with the 470 stroker kit in. that is as big as i can go and these heads are all out 375cfm 2.25valve heads.
i know it will have to rev and wonder what you can get the 1/2 pickups to safely oil at rpm wise or should i go external like my car is.
Re: 1/2" oil pickup or external to pan? for a 400b 470 [Re: dmking] #1300915
09/09/12 09:27 PM
09/09/12 09:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use the stock 6 quart OEM 1970-71 Mopar street Hemi and 440 6 pak oil pans and the stock 440 3/8 pick up My car runs high nines to low tens corked up on Oregon pump gas, 518 C.I. in a 3450 lb. Duster. I've built a bunch of B-RB and 426 Hemi motors over the years, some with external oiling and some with stock type oiling like my current combination is. I really like the current deal, I shift at or above 7000 RPM on every run no oiling problems in 6 years of beating on motors in the car with that set up
Re: 1/2" oil pickup or external to pan? for a 400b 470 [Re: dmking] #1300916
09/09/12 10:14 PM
09/09/12 10:14 PM
NC
440Jim Offline
440Jim  Offline
NC
A well setup 1/2 NPT internal pickup with a good windage tray and 8 qt pan can support 7500 rpm (7000 easy). I know most people switch at this point, but it isn't needed if everything else is right.
But if you already have the external oil pickup system, why not use it?
Re: 1/2" oil pickup or external to pan? for a 400b 470 [Re: 440Jim] #1300917
09/10/12 10:06 PM
09/10/12 10:06 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
hey 440jim. go to cecil much?
broke both engines there
