Re: 340 oil pump gasket?
[Re: HOT IN AZ]
#1300467
09/09/12 03:55 PM
09/09/12 03:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Changing the oil pan on my 340 Demon and naturally I needed to change the pickup. Had to remove oil pump from engine and noticed there wasn't a gasket there. I did not originally assemble this motor so I can't say as there was a gasket supplied. Looking at various sites and some suppliers show a gasket and some don't. Dodge shop manual says nothing about a gasket. Oil pressure was good, 100psi at 6000rpm maybe a little high. Question is "should I use a gasket"? Thanks for your replies
Dont bother... its not needed
[Re: TrWaters]
#1300469
09/09/12 08:51 PM
09/09/12 08:51 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I've been here long enough to know this has the potential to end up like a pinion angle thread..
In any event I didn't use one on my 408.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: krw71ragtop]
#1300471
09/09/12 08:55 PM
09/09/12 08:55 PM
Posts: 3,396 Pa
Hot 340
Pa
I just make the gasket out of a cereal box.
Too thick of material, and asking for a problem IMO .. just leave it out, its what the factory did.
[Re: krw71ragtop]
#1300473
09/09/12 11:06 PM
09/09/12 11:06 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
If that gasket fails, it'll have real low psi and cause engine failure. Don't use it!!
Brian Hafliger
