68 Charger Hellwig 5903 swaybar: control arm bracket ? #1300350
09/09/12 12:08 PM
09/09/12 12:08 PM
Coram, NY
Pool Fixer Offline OP
Coram, NY
Car came with factory front sway bar. The control arm brackets interfered with the calipers when I installed A body spindles/disc brakes many years ago. I trimmed the factory brackets and redrilled the holes in what was left of them for the end links on my factory bar. The whole set up ended up putting the end link bolt closer to the control arm. It was a rig job at best...not alot of meat left and over the years the hole I drilled got hogged out....fast forward to a few years ago, I had an accident and had to replace the drivers side arm. I got one with a factory sway bar tab. despite me telling the body shop that they would have to do something with it...they just installed as is. I didn't know this till yesterday when I was putting the new hellwig bar on. I don't even know how the car has been steering..the caliper slams into the tab with the wheels almost straight.
So here I am with one boogered up tab and one factory tab that's hitting the caliper. I decided to start fresh since the hellwig bar comes with it's own bolt on brackets so I cut off my death race cob job brackets.
I bolted the brackets to the shock bolt as per the instructions...Even though this bracket is different from the factory tab, it hits just as bad....
Here is how the instructions say to install it:
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300351
09/09/12 12:18 PM
09/09/12 12:18 PM
Coram, NY
Coram, NY
I flipped the bracket upside down and shortened the spacer on the end link.
2 questions:
1. does end link length effect fuction of the bar? The end of the bar is at the same spot it would have been had I done it their way. The anchoring point on the arm didn't move in or out.
2. I'm getting the slightest contact between the strut rod and the bushing/washer on the end link due to the angle. If the link was straight up and down, It would be fine. I was thinking of trying to push the front brackets back. They are two piece and I think I could get it to push the whole bar back, this would make the links straight.. any thoughts on that?
I really want to keep the calipers where they are.
plan b is a friend of mine who welds is going to be installing LCA reinforcing plates on my arms so he can fabricate something...
Here is what I did.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300352
09/09/12 12:20 PM
09/09/12 12:20 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Move the calipers to the rear by switching spindles side to side. I believe 66-69 Bendix 4 piston calipers were rear mounted originally.
You will need new brake hoses though.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: autoxcuda] #1300353
09/09/12 12:36 PM
09/09/12 12:36 PM
Coram, NY
Coram, NY
something in me just doesn't want to do it lol...
I will have it all apart soon anyway to take arms off, install new tbars and UCA's... does anyone know of a factory hose that will work for this?
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300354
09/09/12 12:50 PM
09/09/12 12:50 PM
So Cal
So Cal
Pain to do just for an sway bar install project. But not a big deal when you are doing all that other stuff.
Edit: You've got pin caliper I looks from that pictures.
Edit: You're brake hard line is behind the UCA from that picture.
You need a banjo type end brake line. One without a metal tubed extention. Do some research, but IIRC, it is from a Cordoba. I got one out of the junk yard 18 years ago and can't remember. I've upgraded to braided line since.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300355
09/09/12 01:12 PM
09/09/12 01:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why do you insist on hacking something that could fail when all you need to do is put the calipers on the back of the spindle?
Just swap them side to side and be done with it. You're going through a lot of needless work for no good reason.
In the time it took you to make this post would could have been half way done with it already.
- Stu Harmon
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300356
09/09/12 01:29 PM
09/09/12 01:29 PM
AndyF Offline
AndyF  Offline
I showed how to hang the calipers to the rear in my B-body book. I'm sure you have a copy of the book since your car was featured in it.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300357
09/09/12 09:28 PM
09/09/12 09:28 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I personally dont think that it does, but that is just an opinion. If you are talking about an inch or two. Obviously, if you extend it out, the rate of deflection will increase. This will result in a less effective sway bar.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: feets] #1300358
09/09/12 10:38 PM
09/09/12 10:38 PM
Coram, NY
Coram, NY
lol means ha ha ha ha I know I'm being a baby but I see you're point
does anyone know of a factory hose that will work for this? means that I'm asking if anyone knows of a brake hose that will work for swapping the spindles from side to side.
Not sure what I did to earn the dressing down but whatever it was, sorry to have bothered you. I didnt even make fun of you when you traded your testicles in for a smart car...no good deed goes unpunished I guess
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: autoxcuda] #1300359
09/09/12 10:44 PM
09/09/12 10:44 PM
Coram, NY
Coram, NY
exactly! bracket is on frame behind control arm and moving caliper to the back results in way to much hose flopping in the breeze...plus what you pointed out about the hose going dead straight into the caliper. Most of my stuff should be coming in a week or so. At that point I'll have it all apart anyway so I'll deal with it then.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300360
09/10/12 10:33 AM
09/10/12 10:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Either move the calipers to the rear by swapping the spindles L to R, or run a Hellwig 70 B body bar and 70-2 B body or 70-4 E body lower control arms to run the calipers up front
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: DAYCLONA] #1300361
09/10/12 03:33 PM
09/10/12 03:33 PM
GA
roadrunninMark Offline
GA
I did the disc brake swap from the moparts action archive (calipers in front)to my 71 e body. I didn't have tabs on the lca stock but will be adding the sway bar and tabs. Can I just order the bar that will fit the e body and tabs and not have to worry about them hitting the bar or will I need to order something else?
Thanks.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300362
09/10/12 04:08 PM
09/10/12 04:08 PM
So Cal
So Cal
In a week or so you'll have it all apart to swap the spindle to the rear. All that stuff will be coming off anyways.
*Might be interesting to test the car now. Then you get an idea of the incremental changes and improvements done to the car.*
Here's a banjo braided line setup that will work for you with your slider calipers.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: roadrunninMark] #1300363
09/10/12 04:18 PM
09/10/12 04:18 PM
So Cal
So Cal
Thanks.
70-74 E-bodies, 70-72 B-bodies, and 73-76 A-bodies (or cars using those K-frames) with factory sway bar are easy. They all have a narrow type sway bar that will allow your brakes to be mounted in the front or rear. Your choice, no sway bar interference.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: autoxcuda] #1300364
09/10/12 04:37 PM
09/10/12 04:37 PM
GA
GA
Thanks Steve
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300365
09/10/12 05:32 PM
09/10/12 05:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Don't worry. I still have my testicles. I'd prove it to you but the mods would get upset and you might feel insufficient afterwards.
I still have the Imperial and D250 diesel in the driveway.
- Stu Harmon
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: feets] #1300366
09/10/12 09:19 PM
09/10/12 09:19 PM
Coram, NY
Coram, NY
even if the mods let it go, i think the laws of physics preclude a man and his testicles from occupying the same space at the same time in there LLLL....OOOO...LLLL even if you could, it would look darn peculiar as you drove down the street with the twins riding shotgun.
2 movie references in there for those who are paying attention
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Pool Fixer] #1300367
09/10/12 09:21 PM
09/10/12 09:21 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
This is going nowhere.
This is Moparts, not MoBalls.
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: autoxcuda] #1300368
09/10/12 09:28 PM
09/10/12 09:28 PM
Coram, NY
Coram, NY
.......*Might be interesting to test the car now. Then you get an idea of the incremental changes and improvements done to the car.*......
i like the idea but how would i go about that in a measurable way? btw im referring to the cars performance not the proposed texas testicle measuring contest
Re: 68 Charger Hellwig 5903 swaybar: control arm bracket ? [Re: Kern Dog] #1300369
09/10/12 09:31 PM
09/10/12 09:31 PM
Coram, NY
Coram, NY
i get them mixed up... i just got a PM from one of my buddies over at moballs asking what i meant by sway bar.
