Re: How much chain slop is too much? [Re: fiddlestix] #1300275
09/10/12 04:44 PM
09/10/12 04:44 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Tim
I had the same problem with my 40 block. I went with a -5 undersized chain and no more slop. Chain is tight and zero timing wiggle movement now. Have not had a problem with it in over 5 years now.
Old Geezer Racing
Re: How much chain slop is too much? [Re: Stanton] #1300276
09/10/12 04:52 PM
09/10/12 04:52 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Oversize chains ?!?!?! All chains are the same - its the top sprocket that's oversize. Which allows you to replace worn chains with any "off the shelf" double roller chain.
NOPE, not true!
I had too much slack in my brand new cloyes roller chain set. I bought a -5 chain (undersized) and there is no more slack. I used the same new gearset I already had, but I replaced/swapped 1 new chain for another new chain. I believe the -5 chain may have had oversized rollers. That is the only thing I can think of that would take up the slack difference.
Old Geezer Racing
Re: How much chain slop is too much? [Re: SCATPACK 1] #1300277
09/10/12 05:52 PM
09/10/12 05:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Strange that they don't list or mention shorter chains in their catalog ... and only reference undersize sets !!!!
Re: How much chain slop is too much? [Re: Stanton] #1300278
09/10/12 06:58 PM
09/10/12 06:58 PM
Ohio
fiddlestix Offline OP
Ohio
Well, I may be in luck. Thanks to one of the Moparts sponsors. He says he can get .001", .004", .005" and .010" oversized rollmaster timing sets. I ordered the .004" set and should have it in 3-4 days(drop shipped to me). If he comes through believe me you, I will let you guys know who it is and how helpful he has been.
Re: How much chain slop is too much? [Re: fiddlestix] #1300279
09/21/12 09:21 PM
09/21/12 09:21 PM
Ohio
Ohio
Well, I finally got the timing chain all sorted out. I have been dealing with Todd at Marsh performance in N.C. His supplier told him he could get rollmaster in several different sizes. Well.... they came back after I told him I wanted a .004" oversize that they could only get standard sets. He then ordered me a .005" Cloyes set (to be drop shipped)and said I could return it if it didn't fit(for a standard Rollmaster). When it arrived last Friday it was a standard set. So, I called him right away and he got the .005" set reordered. It came in Thursday and fit great!!!!! He is sending me a return shipper for the standard set they sent me. I would say he has gone above and beyond for a $125 part. Which by the way is an excellent price. I would highly recommend him to anyone.
Thanks Todd
