Dual point distributor caps #1300214
09/09/12 01:45 AM
09/09/12 01:45 AM
Illinois
SGTFURY62 Offline OP
Illinois
Can you use a single point cap in place of a dual point cap? Thanks
Re: Dual point distributor caps [Re: SGTFURY62] #1300215
09/09/12 02:16 AM
09/09/12 02:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No.... But these are the pt numbers that do fit....
Prestolite Caps & Rotors
AL66 Niehoff is the cap AL43 Niehoff is the rotor
A304 Delco cap, A403 rotor
AL129 Echlin(Napa) stock cap, AL125 rotor
AL1290 Echlin(Napa)performance cap,AL1250 rotor
C152 Borg Warner Cap, D135 rotor
AL122 Filko Cap, AL121 Rotor
3-35 motorcraft 4-7 rotor
AL135 Standard Ignition cap, AL153 rotor
Re: Dual point distributor caps [Re: 1_WILD_RT] #1300216
09/09/12 02:57 AM
09/09/12 02:57 AM
Illinois
Illinois
Thanks!
Re: Dual point distributor caps [Re: SGTFURY62] #1300217
09/09/12 09:27 AM
09/09/12 09:27 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
As far as I know the old Standard cap - pt
# AL1680 is/was the only one thats tan in color(long dis-continued btw )
all the rest are either blue, black , red or grey
I have maybe a dozen of these left
Re: Dual point distributor caps [Re: gtx6970] #1300218
09/09/12 12:21 PM
09/09/12 12:21 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I've kept some old Standard Ignition AL-148 tan caps (new in boxes) with tall center towers that look just like the ones pictured above, but they have ~Made in USA~ cast on the top of the cap. Any opinions as to what years and engines they fit?
