degreeing roller cam Please Help *DELETED*
#1299680
09/08/12 11:32 AM
09/08/12 11:32 AM
Posts: 466 Ohio
fiddlestix
Ohio
Post deleted by fiddlestix
Re: degreeing roller cam Please Help
[Re: fiddlestix]
#1299682
09/08/12 01:50 PM
09/08/12 01:50 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Did the cloyes come with the bearing or are you trying to add one in??? Think if it was not a set with the bearing the rear of the top gear needs to be milled the thickness of the bearing? Maybe a screw up in top gears??
[Re: Dodgem]
#1299683
09/08/12 01:59 PM
09/08/12 01:59 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
That set wasn't designed for a thrust bearing. Those with the thrust bearing have a "T" in the part number like 9-3525TX9. The cam sprocket is machined differently for the thrust bearing.
[Re: fiddlestix]
#1299685
09/08/12 06:14 PM
09/08/12 06:14 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
When I built my buddies Ford (yea I know) 460 it even gave instructions with the roller thrust bearing to have the cam gear machined on the back where the bearing rode. It gave all the dimensions and I had my buddy at the local machine shop cut it. Ron
