NE1 know a place to read up on 6volt postive grounds? #129912
09/29/08 11:49 PM
09/29/08 11:49 PM
restos just aren't my thing
gtsuperbee Offline OP
I am rewiring a 53 cranbrook with an aftermarket universal 6 volt harness. It is for a negative ground. What changes do I need to make for a positive ground. I believe I will need to polarize the generator when I am done also. Can you guys steer me in the right direction. THX
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: NE1 know a place to read up on 6volt postive grounds? [Re: gtsuperbee] #129913
09/30/08 09:07 AM
09/30/08 09:07 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
check out http://www.merc583.addr.com/mopar/framesets/techtipframeset.html
that should get you what you need!
Re: NE1 know a place to read up on 6volt postive grounds? [Re: RodStRace] #129914
09/30/08 01:05 PM
09/30/08 01:05 PM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
If not, do a search on the P15-D24 site, I read it there before.
