4/7 swap roller cam ? #1298263
09/06/12 06:53 AM
09/06/12 06:53 AM
Washington
skrews Offline OP
skrews  Offline OP
Washington
anyone know if there are 4/7 swap cam cores available for solid roller small block ? OE 59* block standard journal size
would like to do the 4/7 swap and have an iron gear pressed on too
Re: 4/7 swap roller cam ? [Re: skrews] #1298264
09/06/12 09:20 AM
09/06/12 09:20 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
LSM made a 4/7 swap cam for my Big Block Mopar. I had it made in the 54 mm cam core size to strengthen the cam core and allow me to run the roller cam bearings as well.That was about a $1,000.00 up grade with the machine work,bearings and camshaft.But I'm sure they can make you a standard core size camshaft with the 4/7 swap.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 4/7 swap roller cam ? [Re: MRMOPAR622] #1298265
09/06/12 11:48 AM
09/06/12 11:48 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Crane Cams offers the 4/7 swap 8620 steel billet roller camshafts for the 59 degree engines with standard journal size. Regards, Chase
Re: 4/7 swap roller cam ? [Re: cknight] #1298266
09/06/12 05:26 PM
09/06/12 05:26 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
thanks for the info guys
