More Bonneville 2012 270mph+ Mopar #1297897
09/05/12 12:20 PM
09/05/12 12:20 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Re: More Bonneville 2012 270mph+ Mopar [Re: TrWaters] #1297898
09/05/12 12:31 PM
09/05/12 12:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
62% throttle position and 132 lb boost I wonder how fast it would have gone at WOT
Re: More Bonneville 2012 270mph+ Mopar [Re: Cab_Burge] #1297899
09/05/12 12:36 PM
09/05/12 12:36 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Reading on bangshift that the car did 283 mph.
Re: More Bonneville 2012 270mph+ Mopar [Re: TrWaters] #1297900
09/05/12 12:47 PM
09/05/12 12:47 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Re: More Bonneville 2012 270mph+ Mopar [Re: Cab_Burge] #1297901
09/05/12 02:04 PM
09/05/12 02:04 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
132kpa is about 4psi boost. Must be some wicked motor!
Re: More Bonneville 2012 270mph+ Mopar [Re: TRENDZ] #1297902
09/05/12 04:02 PM
09/05/12 04:02 PM
pennsylvania, usa
David Barton Offline
pennsylvania, usa
I'm proud to say that the engine was built here at Ray Barton Racing. Lee Sicilio has been a customer here for many years. He is a stand up guy.
Congratulations Lee on a record setting performance with a brand new car. Hope you hit the 300 mph mark next time.
Here is another great article about the whole project and everyone involved. This is one hard working team.
http://bangshift.com/blog/car-feature-le...e-think-so.html
Re: More Bonneville 2012 270mph+ Mopar [Re: David Barton] #1297903
09/05/12 09:38 PM
09/05/12 09:38 PM
Out West
408strokerdart Offline
Out West
I'm proud to know the guy that built the chassis at Brink Racecraft. Ryan Fain did a fantastic job on this car and I was able to see it at almost every stage since that is where I get chassis work done. Lee had a big commitment to complete this car and had the right people involved. I think it had an outstanding first outing. I predict 330 is achieveable from this combo.
Re: More Bonneville 2012 270mph+ Mopar [Re: TRENDZ] #1297904
09/05/12 09:41 PM
09/05/12 09:41 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
How does that work? 132 kilopascals = 19.14498 PSI according to every calculator I can find....
Still a Bad Monkey regardless..........
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: More Bonneville 2012 270mph+ Mopar [Re: Sledge_57] #1297905
09/05/12 10:45 PM
09/05/12 10:45 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
When you see manifold pressure read in kPa, it's usually absolute pressure, not gauge pressure.
Bonneville is at about 4200 feet above sea level, which is approximately 86 kPa of barometric pressure. 132-86 = 46 kPa of boost, or a little less than 7 psi. Trendz assumed a standard sea level barometric pressure.
Edit: if you watch the start of the video it's reading a manifold pressure of 60 kpa or so. That's in a vacuum condition, only diesels sometimes run above atmospheric at idle. I think I also saw a peak of 150 kPa on the gauge during the run, which is closer to 9.3 psi of boost.
Re: More Bonneville 2012 270mph+ Mopar [Re: David Barton] #1297906
09/05/12 10:49 PM
09/05/12 10:49 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Nice job David....
RIP Monte Smith
Re: More Bonneville 2012 270mph+ Mopar [Re: Blusmbl] #1297907
09/05/12 11:02 PM
09/05/12 11:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
About 1900* exhaust temp , that's a little warm ...
Re: More Bonneville 2012 270mph+ Mopar [Re: CompWedgeEngines] #1297908
09/06/12 01:09 AM
09/06/12 01:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Got to get there someday... Cools stuff at the flats.
Re: More Bonneville 2012 270mph+ Mopar [Re: J_BODY] #1297909
09/06/12 09:29 AM
09/06/12 09:29 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Hearing him pull high gear at around 207 m.p.h. was a " holy smokes " moment for me.
Awesome in it's awesomeness.
Well done to everyone involved in this project.
That is just too cool.
Re: More Bonneville 2012 270mph+ Mopar [Re: tubtar] #1297910
09/07/12 04:41 PM
09/07/12 04:41 PM
Omaha, NE
dieselgeek Offline
dieselgeek  Offline
Omaha, NE
Hi Guys,
Been following some of the stats on my Youtube video above and was glad to see 370+ hits from the Moparts forum...!
I posted the video, I'm also the EFI tuner / electronics geek on Lee's car.
The first thing I wanted to say was how happy we are with David, Ray, and everyone else at Barton Racing. They built us an engine that had ZERO mechanical issues and that's saying a lot for an engine that has to live at these power levels for 7 miles at a time... which equals a LOT of passes at the drag strip. Although he seriously considered other builders with "more turbo experience," Lee's long standing relationship with the Barton family convinced him to trust them with a Turbo engine build which they executed perfectly. The engine didn't even break a sweat. These guys know their stuff when it comes to Hemi Chryslers, period.
(I should add that David and Ray also supplied us with the engine that holds the current A/PRO record at Bonneville, one of the more prestigious classes (fastest naturally aspirated Production body car in the world) in the #1001 car. We've taken that engine to the salt 5 years in a row without so much as a refresh - it just refuses to break and the Chevy/NASCAR boys have been chasing us the entire time (they qualified on our record once but weren't allowed to return due to rules violations, heh).)
We ended up taking the A/BGALT record this year on our first try - the 300+mph goal is next after Ryan Fain performs some suspension and aero tweaks. I'm so fortunate to be able to work with all these guys!
In case anyone is interested, another unique feature on Lee's car is that all of the engine management and data gathering are 100% Open Source. We use a Megasquirt 3x system for fuel, ignition, boost control, fault management (caution/shutdown lights), etc. We use a JBPerf.com "IO Extender" to gather data from EGTs, AFRs, 4 suspension travel sensors, front and rear wheel speed sensors, turbine speed sensors, GPS data, coolant pressure&temp, oil pressure&temp, intercooler fluid temp, pre and post intercooler intake air temps, and a few other misc inputs. We're using Spaghetti Menders for the primary power controls in the car which made the wiring task a lot easier.
Add to that, I assembled an "in-car PC" which gathered the data from the Megasquirt and IOX systems in realtime, just like a laptop but bolted to the chassis. I then used a wi-fi card in that PC (which runs Linux instead of Windows), configured as a WiFi Hotspot. I connected to it with my laptop from inside the Chase Vehicle, and was able to monitor and tune real time via wireless while the car was on-course. All of this was done at extremely low cost compared to using commercially available systems, although it was a bit DIY-intensive.
The most helpful data by far are the suspension travel sensors. They tell us we have 1000+ lbs of downforce from Aero on the nose of the car, enough to push us past the weight ratings of the front tires. Ryan and Neil have a plan to fix that for next year.
Someone asked about EGTs. Realize we are sampling at the exhaust port in the center of the stream, not where most people take their samples. On a turbo+gasoline engine you'll get these kinds of EGTs. Confirming that the tune is OK is the fact that the spark plugs coming out of the engine looked just like we wanted, a little fuzzy from being safely rich, but still sharp edges on the ground strap and electrode - we're not burning them at all, which is good because we plan on feeding more boost into the engine on the next trip.
Sorry if my post is long-winded, I figured some of you guys on Moparts would appreciate hearing the details. If you have questions, feel free to ask.
-Scott Clark
Re: More Bonneville 2012 270mph+ Mopar [Re: dieselgeek] #1297911
09/07/12 05:01 PM
09/07/12 05:01 PM
Out West
Out West
Hi Guys,
-Scott Clark
Thanks for that Scott. Very informative.
Re: More Bonneville 2012 270mph+ Mopar [Re: 408strokerdart] #1297912
09/07/12 05:53 PM
09/07/12 05:53 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Scott is also quite involved with the early hemi EMC entry.
Re: More Bonneville 2012 270mph+ Mopar [Re: dieselgeek] #1297913
09/07/12 08:51 PM
09/07/12 08:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
awesome ride, felt like i was next to the driver. why was the throttle only at 62%?
Re: More Bonneville 2012 270mph+ Mopar [Re: rickraw] #1297914
09/07/12 10:37 PM
09/07/12 10:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
keeping the car as hooked as you can i would think.
Re: More Bonneville 2012 270mph+ Mopar [Re: Clanton] #1297915
09/07/12 10:54 PM
09/07/12 10:54 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Awesome ride! And thanks for the backstory!
Wow! What a car. Beautiful work on the chassis and accessories based on the article photos. A true work of art!
