Oil sending unit 69 charger ....tech needed #1297806
09/05/12 03:11 AM
09/05/12 03:11 AM
long island
autodynamics Offline OP
long island
When I first put together my motor I had gone to the local parts store and bought a new oil sending unit, the gauge showed 60-80 lbs running,
Sometime later the sending unit took a dump, the connector on the bell was loose so I replaced it, since then I have changed it 6x only for the gauge to read 20-40lbs
The sending units look identical and no part #
On them ,
I believe they made a few different models with different ohms
Resistance ,
It's a ralley cluster and I'm using a ps-59 standard sending unit
I have tried a Oem one as well with same low psi results
Thanks in advance
Pete
Re: Oil sending unit 69 charger ....tech needed [Re: autodynamics] #1297807
09/05/12 03:28 AM
09/05/12 03:28 AM
long island
long island
Btw it's not the oil, I ve have checked it all out , it's the sending unit,
Re: Oil sending unit 69 charger ....tech needed [Re: autodynamics] #1297808
09/05/12 03:53 AM
09/05/12 03:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Post a picture of the sender your using... BTW the OE manufacturer was Introl....
Have you tried installing a mechanical gauge temporarily to check the oil pressure?
Might try contacting member JoeSixpack to see if he's got a quality vintage sender..
Re: Oil sending unit 69 charger ....tech needed [Re: 1_WILD_RT] #1297809
09/05/12 04:16 AM
09/05/12 04:16 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
The oil sending units on the market are a hit and miss in quality. I went thru a dozen or more 'till I could find one that would read over 40 lbs of pressure. I hooked a mechanical gauge to oil pressure so I would know true reading and what ball park reading I was trying to achieve from rally gauge.
You say you even tried an OEM sending unit.........they are somewhat on the expensive side. I've seen them go for around $180. Cannot locate one any cheaper in price. Although the money I've wasted buying aftermarket crap......I wish I had put towards an original sending unit.
Re: Oil sending unit 69 charger ....tech needed [Re: 1_WILD_RT] #1297810
09/05/12 07:23 AM
09/05/12 07:23 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I just hooked up a mechanical gage on my Hemi, worried about the low oil pressure I thought I had on a break in motor. The Hemi is fine.
The difference from the mechanical gage and the electric was stunning. I changed sending units and they still don't agree, but the new one was closer.
I will probably take off the mechanical gage but only after I have a mental fix on the correlation. For the electrical stock gage, no oil pressure would be a right reading. Low might be low. High is high. That seems to be the accuracy.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Oil sending unit 69 charger ....tech needed [Re: Kowal] #1297811
09/05/12 03:18 PM
09/05/12 03:18 PM
long island
long island
Ok I will post a pic up however it's the standard bell style sending unit with the spade terminal
I did try another gauge and it's not the problem
The sending unit must be different in the way the resistance
Works .,
I put the old one in and oil pressure is high
I put any other ones in and they all read low
My question is
Are there two different types of bell style oil pressure
Sending units ? Or is it just one style?
The auto parts store says its the only one available
Strange
I do want to keep my factory gauge
Re: Oil sending unit 69 charger ....tech needed [Re: autodynamics] #1297812
09/05/12 07:19 PM
09/05/12 07:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I can't say for sure, but I see no reason for more than one type, as they all measure the same thing in the same manner. The dashes all work in the same ohms don't they?
Did you try a mechanical gauge?
I have mechanical Aptitude.
I can screw up anything.
Re: Oil sending unit 69 charger ....tech needed [Re: autodynamics] #1297813
09/05/12 07:29 PM
09/05/12 07:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My question is
Well do they mean it's the only one listed for Mopar that's available or the only one thats available period, cause if they are selling you a GM part the resistance is wrong....
Re: Oil sending unit 69 charger ....tech needed [Re: autodynamics] #1297814
09/05/12 10:11 PM
09/05/12 10:11 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
On them ,
Resistance ,
Thanks in advance
Pete
Here is link for an original OE type, made in the USA not China or Mexico....
From Rich Ehrenberg...
http://www.ebay.com/itm/Mopar-Oil-Pressu...-/221119969388?
pt=Vintage_Car_Truck_Parts_Accessories&hash=item337bc6f86c&vxp=mtr
Note that there are differences because inside the sensor is a variable resistor which has a % tolerance..
Just my $0.02..
Re: Oil sending unit 69 charger ....tech needed [Re: Sinitro] #1297815
09/06/12 01:27 AM
09/06/12 01:27 AM
moparjo68 Offline
moparjo68  Offline
Question: I clicked on the above link and looked at the oil sender unit. The patent number on it has the same patent number as the oil sender I bought from NAPA. This product on ebay, is it the same part I bought from NAPA since the patent numbers are the same????????
Re: Oil sending unit 69 charger ....tech needed [Re: moparjo68] #1297816
09/06/12 02:02 AM
09/06/12 02:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I just clicked on the link & I have a concern with the unit, probably a good sender but I'd strip the teflon tape off the threads, the sender is a variable resistor so the teflon tape prevents a good connection to ground so it would cause a low reading.... I've never used sealer on the oil sender or the temp sender for this very reason & I've never had a leak from either....
Re: Oil sending unit 69 charger ....tech needed [Re: 1_WILD_RT] #1297817
09/06/12 02:50 AM
09/06/12 02:50 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
1 RT kinda hit on what I was going to ask you-
How good is the ground at the sender- too much teflon tape will prevent a good contact and give a low reading.
In a similar vein- how about your dash grounds? If they are weak, then you will get similar readings.
I've learned through the years to check my grounds first- especially if I am going through sending units.
Also- I always attach a 'known good' mechanical gauge- even if it temporary- to check my pressures if I think there may be an issue.
Better to be sure then to be out a engine because you had low oil pressure.
Good Luck with it,
CC.
Re: Oil sending unit 69 charger ....tech needed [Re: 1_WILD_RT] #1297818
09/06/12 10:19 PM
09/06/12 10:19 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Keep in mind..
That the NPT is tapered so as the sensor is torqued down any teflon sealing tape will be worn down so the end tip of the sensor is down to metal-to-metal in its deepest penetration..
Also note that the mentioned sensor is made by the original factory that produced the Chrysler OE part...
IMHO..
I don't like any brand after-market sensors as they can be all over the map for electrical tolerances possibly leading to errors for its readings. I prefer to stay with the OE versions whenever possible..
Just my $0.02..
Re: Oil sending unit 69 charger ....tech needed [Re: Sinitro] #1297819
09/07/12 12:28 AM
09/07/12 12:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Keep in mind..
IMHO..
Just my $0.02..
I agree aftermarket sensors are all a question mark, and yes I understand NPT is a tapered thread which should cut through the tape & give a good ground, but I prefer not to chance it... I've never had a leak running without teflon tape & I know I get a positive ground... And that's my
