Look what followed me home last friday
#1297489
09/04/12 08:00 PM
09/04/12 08:00 PM
Posts: 680 NW IL
Biggie
NW IL
Its a 1954 chrysler new yorker.
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon 03 chrysler 300m 10 dodge charger
Re: Look what followed me home last friday
[Re: Biggie]
#1297490
09/04/12 08:08 PM
09/04/12 08:08 PM
Posts: 680 NW IL
Biggie
NW IL
It has the 331 hemi with the 2 spd power flight trans. appears to be all original. Dad and I got it to fire up today. Motor sounded decent. Tomorrow hopefully we can get the brakes to work.
[Re: fstfish66]
#1297494
09/18/12 01:26 PM
09/18/12 01:26 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Nice score. My dad used to have a red 53' 2 door New Yorker with a Hemi. It ran & drove & everything worked. It was just all wore out. I was to young to snag it at the time but he sold it for $1500.00. Wish I had it now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dogdays]
#1297498
09/19/12 09:44 PM
09/19/12 09:44 PM
The 54 New Yorker DeLuxe was the first Chrysler with a 4-barrel carb. Also was the first with dual exhaust, I believe. And (as noted above), the 54's have much improved heads over the 51-53 models.
235 horsepower, which at the time was the highest of any American production car. (Non DeLuxe 54 New Yorkers had 195 hp and a two barrel carb)
#1297499
09/19/12 10:57 PM
09/19/12 10:57 PM
Posts: 680 NW IL
Biggie
NW IL
I have the two barrel. Probably getting a new dual exhaust put on though. If i can find a regular 4bl intake that i can afford i am going to upgrade.
[Re: Biggie]
#1297500
09/25/12 05:30 PM
09/25/12 05:30 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
you can find those 4bbl intakes not hard to find,,, look over on hot hemi heads . com they have a free swap meet on line,,,, they also have new aftermarket aluminum intakes,,might be cheaper then a used 50 plus year old iron intake that some one thinks is gold plated,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: TrWaters]
#1297506
11/28/12 11:46 PM
11/28/12 11:46 PM
Posts: 10,587 Freeport IL USA
poorboy
Freeport IL USA
Biggie is my son.
This Chrysler New Yorker Newport is a 2 door hardtop with the standard short block 331 Hemi. Trust me, we have hammered this out over on the HAMB board, I know which block we have, and it is the newer block. We have determined this is likely a middle of year produced car. It has a 2 bbl carb and he has found and purchased an original 4 bbl intake and carb. We will probably install the intake and carb next spring.
We have rebuilt the front brake wheel cylinders, repacked the wheel bearings, and we have installed right hand studs and lug nuts in place of the wheel bolts. We have rebuilt the master cylinder. We were able to pull the rear hubs off and rebuilt the rear brake cylinders, replaced the brake shoes, and repacked the rear wheel bearings and replaced the outer axle seals. The brakes and e-brake work awesome.
We have added an alternator, retained the generator to drive the power steering pump, replaced the belts, all the hoses, and have completely rewired the car, front bumper to the rear of the car. We have updated all the light sockets and have installed all new 12 volt bulbs.
Though the tires are almost new as far as tread is concerned, they are weather checked very badly. He has decided he needs to change the tires before he drives it, and he still needs to have the exhaust done. He is unable to change the exhaust do to a back injury, and I am NOT going to lay on my back to cut off exhaust bolts, he will have to pay someone to do it, unless one of you is volunteering. He as been quoted custom dual exhaust system for less then a single exhaust system, in the mid $400-$500 range.
The car is parked in his garage until spring. The wiring update took much longer then expected. Old positive ground switches don't mix well with currently available electrical connections and wiring harnesses. It was a major PITA. Gene
[Re: Webster]
#1297508
12/06/12 01:43 PM
12/06/12 01:43 PM
Posts: 2,129 Vermont
TrWaters
Vermont
Good for you. I did not say it was an extended block. I said the chances were good it could be because of the changeover in early 54,and the fact is was a 2bbl, which is not usually associated with a 54.
