How far to Install Cam Plug
#1297335
09/04/12 04:30 PM
09/04/12 04:30 PM
Posts: 5,161 CT
GTX MATT
CT
How far should I drive the cam plug in? I have what I would consider a deeper plug. Should I use any sealer on it?
What are you guys using for sealer on the rest of the core plugs?
Re: How far to Install Cam Plug
[Re: GTX MATT]
#1297336
09/04/12 05:06 PM
09/04/12 05:06 PM
RapidRobert
How far should I drive the cam plug in? I have what I would consider a deeper plug. Should I use any sealer on it? What are you guys using for sealer on the rest of the core plugs?
(1) not sure (2) Permatex #1 in the toothpaste like tube (3) Same stuff
[Re: Cab_Burge]
#1297339
09/05/12 11:39 AM
09/05/12 11:39 AM
Posts: 5,161 CT
GTX MATT
CT
Its a 440, its a 1968 block
[Re: GTX MATT]
#1297340
09/05/12 12:38 PM
09/05/12 12:38 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use Permatex avation sealer on my core plugs.It's the liquid small bottle with a brush in the cap.
[Re: Cab_Burge]
#1297342
09/05/12 05:10 PM
09/05/12 05:10 PM
A Mopar crank bolt washer welded on a pipe is the perfect cam plug driver for a BB Mopar--drive it all the way in--you can even use two if you want to make sure and keep that clutch dry--I have always used Permatex #2 on freeze plugs, but usually use ultra black or ultra grey on the cam plug--they are the most oil resistant of the RTV family by far--you can even JB Weld the cam plug for that extra touch ( this step reserved for those who actually had one leak in the past)
