Percy's Seal-4-Good Header Gaskets
#1297082
09/04/12 10:56 AM
09/04/12 10:56 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Are the Percy's Seal-4-Good (dead-soft aluminum) head gaskets still a good choice? I have a ticking noise on my headers which is pointing towards my header gaskets. My TTi gaskets appear to have made it for about 4 years or so and I need to replace them. I did an internet search and the Percy's and the Cometic's seem to be the two top choices. My local parts store can get the Percy's, so I am leaning towards them for my 340. http://www.summitracing.com/parts/PHP-66037/ Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Percy's Seal-4-Good Header Gaskets
[Re: Triggerfish]
#1297084
09/04/12 12:28 PM
09/04/12 12:28 PM
YO7_A66
Indiana
Do they have a suggested torque spec for correct install? Thank you for your reply.
[Re: YO7_A66]
#1297086
09/04/12 02:23 PM
09/04/12 02:23 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
I just tightened them by feel since they 'crush' to seal.
[Re: Triggerfish]
#1297087
09/04/12 02:44 PM
09/04/12 02:44 PM
YO7_A66
Indiana
Did you install them with the smooth side facing the head? thanks again.
[Re: loco340cuda]
#1297089
09/04/12 04:56 PM
09/04/12 04:56 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I used them on my 440 with TTIs.They lasted about a week before they leaked.The cheap white ones that came with the TTIs lasted about 4 years.Now I use Mr Gasket Ultra seal.Mine have been on 4 years now.No leaks.Had them on the kids sb truck.I even took the headers off and reused them and they still sealed.The other kid has them on his 413 with headers.They are at least 10 years old.Reused them once and they are still sealed.Rocky
Chrysler Firepower
[Re: loco340cuda]
#1297090
09/04/12 04:58 PM
09/04/12 04:58 PM
YO7_A66
Indiana
Remflex was also one of my considerations. It is hard to find something bad on the net when it comes to Percy's, Cometic, or Remflex header gaskets. My local store was able to get the Percy's out of the three mentioned brands.
Thanks for the reply.
[Re: moparjoe360.4]
#1297093
09/08/12 01:23 PM
09/08/12 01:23 PM
YO7_A66
Indiana
I added the Percy's header gaskets and no more ticking. I will re-torque them in a few days just to make sure. One thing that I noticed was when I pulled the TTI gaskets and over-layed the Percy's, the exhaust openings are not the same. The TTi's restricted my outer exhaust tubes slightly on the outer corners. You can see in the picture how dark the TTi's are in the corner. This dark area was restricting the exhaust flow. Probably not enough to hurt but the Percy's are wide open with no restrictions.
